Hi Bunnings workshop community,
I'm looking to see if there is anyone who can advise on this grout situation. In an attempt to clean grout, a metal brush was used which caused the (already old and worn) grout to deteriorate. These left these weird holes (pictures below).
Undamaged grout:
Some samples of damaged grout:
I did a bit of research on grout replacement, but still left with some questions:
- These holes are very much deeper than those around them, will the general advice of removing a thin layer of grout all around and pushing the grout in fill these holes adequately?
- As I understand it grout is porous and not part of waterproofing, however due to the severity of the deterioration should I be concerned at all about water damage due to these deep holes (and if so, what should I be looking for)?
- I want to restore as close to original as possible. How can I identify the grout type I should use? It has a slightly rough texture to it.
- Following restoring it as closely as possible, the grout seems to be recessed a small amount below the tile surface, what's the best way to replicate that evenly?
Any other advice about rectifying this situation would be much appreciated
Appreciate the help as always!
Bill
