My best attempt at doing a Landry Reno on a budget
https://www.bunnings.com.au/70-x-35mm-framing-mgp10-h2-blue-pine-2-4m_p8030953
https://www.bunnings.com.au/dunlop-1-5kg-flexible-coloured-grout-alabaster_p6650193
https://www.bunnings.com.au/selleys-300g-white-wet-area-waterproof-silicone-sealant_p1230981
https://www.bunnings.com.au/ramset-7-x-35mm-green-wall-plugs-25-pack_p2260645
https://www.bunnings.com.au/carinya-250-x-200mm-black-angle-bracket_p3961579
https://www.bunnings.com.au/estilo-stainless-steel-single-bowl-square-sink_p0300746
https://www.bunnings.com.au/zenith-10g-x-75mm-gold-passivated-type-17-countersunk-head-timber-screws-50-pack_p2409151
https://www.bunnings.com.au/kaboodle-2400-x-600-x-36mm-hevea-timber-benchtop_p0082263
https://www.bunnings.com.au/specrite-2700-x-600-x-21mm-oak-timber-acoustic-panel_p0455959
https://www.bunnings.com.au/kaboodle-400mm-white-gloss-modern-cabinet-door_p2664501
https://www.bunnings.com.au/ryobi-18v-one-hp-brushless-sds-rotary-hammer-tool-only_p0294857
https://www.bunnings.com.au/ryobi-18v-one-hp-brushless-210mm-table-saw-tool-only_p0405158
https://www.bunnings.com.au/ryobi-18v-one-8-piece-kit-r18x8c142b_p0539755?store=7213&gclsrc=aw.ds&gad_source=1&gad_campaignid=21118986128&gbraid=0AAAAADtbEB8jFSbIB8zARiodbTYo4AJPL&gclid=Cj0KCQjw9ZLSBhCcARIsAEhGKgPj8uuM7bOFNgaFQ85A-NLTSlGLlQiJA81KPDZEYP_rJfPm-ehVmKEaAoONEALw_wcB
https://www.bunnings.com.au/ryobi-10m-red-cross-line-laser_p0437573
https://www.bunnings.com.au/ryobi-18v-one-4-wet-dry-tile-saw-r18ts-0-tool-only_p6210686
https://www.bunnings.com.au/kinetic-tap-re-seating-tool_p4900115
https://www.bunnings.com.au/monarch-heavy-duty-caulking-gun_p1661920
https://www.bunnings.com.au/qep-tile-sponge_p6659332
https://www.bunnings.com.au/qep-home-pro-grout-float_p6659942
Ripped tiles and old sink out
hung Cabinets and framed hot water box
cut and added beach top and bench shelf, sink and taps
tilled backsplash
plastered framed box around hot water tank
glued on acoustic Panals and cut out secret access door
siliconed everything
painted
Hello @cody5237
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your laundry makeover project.
What a clever laundry makeover! The castellated panels add a beautiful designer touch and cover the HWC elegantly, while the combination of tiles, cabinetry and open shelving creates a space that's both practical and stylish. It's an excellent use of space that proves you don't need a big budget to achieve a polished result.
