I couldn’t find a cabinet or bookshelf that would fit under my sit stand desk that could be used for storage and hide my feet whilst sitting. So I decided to build one for myself as my first furniture making project.
Pine panels -
https://www.bunnings.com.au/specrite-1200-x-405-x-18mm-timber-multi-use-pine-panel_p0419611
I used 18mm thick for the internal uprights and shelves and 26mm thick for the external frame.
finished pine - I used 42 x 18mm x 1200mm finished pine
MDF -
https://www.bunnings.com.au/3mm-mdf-panel-standard-2440-x-1220mm_p0590054
Wood glue - Gorilla wood glue
Paint -
https://www.bunnings.com.au/taubmans-1l-white-semi-gloss-water-based-enamel-paint_p0147167
also taubmans 3 in 1 primer
Hinges - was black flush hinge 20 pack
Door Handles -
https://www.bunnings.com.au/prestige-71mm-black-twist-t-shape-knob_p4023561
Shelf pins - taskmaster 5mm clear shelf pins 20 pack
biscuits - Ryobi joining biscuits size 0
Door latch magnets
table saw, drop saw, biscuit joiner, belt sander, drill press, Corner clamps , Paint brush, Paint Roller, Paint tray, Painters tape
I first chose the size and the style of my cabinet and purchased the best size panels to limit off cuts. I then used a table saw to rip down the panels into 300mm widths, and to cut them to the correct length.
- Step 2:
I then Made a dry fit and made sure everything was square and labeled which lengths of panel were to go where so I wouldn’t get them mixed up. I then used a drill press to make 5mm holes in the uprights to allow me to put in shelves later on. I drilled the complete way through on the middle panels and 10mm deep on the external uprights and only on the inside.
- Step 3:
I then used a biscuit joiner to create the holes for biscuits and wood glue to join the main frame as to not have screw holes to fill in later. I clamped it together checking for square and allowed the glue to dry.
- Step 4:
when dry, I sanded everything, added feet (glued together offcuts and used a drop saw to make even legs) I screwed this on, used a drop saw to cut down the offcuts from the frame to use as shelves. And filled in any holes I could find and filled in the joins where needed, sanded and refilled and repeated until it was smooth. During this time I also cut down an MDF board with a Stanley knife (as I found it gave a cleaner cut) to fit the back of my cabinet.
- Step 5:
I then primed all the individual parts and had the primer tinted grey as I was going to paint a darker colour. (Sat it on some saw horses I made haha) I also sanded with paint sandpaper post priming to allow for a smoother finish.
- Step 6:
I then painted everything with my final colour adding multiple layers sanding between each coat.
- Step 7:
I measured my openings for the doors. I used a drop saw to cut to length and a table router to allow for the MDF to be glued into the frame. I connected these together with wood glue and dowels. I camped them together an allowed to dry.
- Step 8:
I then cut MDF to fit the frames gluing it together and allowing that to dry. I then filled and sanded all the holes.
- Step 9:
Prior to painting the doors, I attached hinges, door knobs, and magnetic latches to make sure I did not need to make any adjustments to make everything flush.
- Step 10:
I primed and painted the doors as I did the cabinet, attached the doors to the hinges, nailed on the back MDF. And now I have my perfect sized cabinet.
