Needed to combine my love of books and video games into one for my small room
https://www.bunnings.com.au/all-set-large-wood-storage-crate_p0214210
https://www.bunnings.com.au/ramset-nylon-wallmate-plasterboard-anchor-with-screws-20-pack_p0643326
https://www.bunnings.com.au/zenith-8g-x-50mm-brass-plated-hinge-long-thread-countersunk-head-timber-screws-50-pack_p2435423
https://www.bunnings.com.au/zenith-8g-x-25mm-brass-plated-hinge-long-thread-countersunk-head-timber-screws-100-pack_p2435075
https://www.bunnings.com.au/dulux-340g-black-flat-finish-spray-paint_p0782657
https://www.bunnings.com.au/bondall-300g-jarrah-monocel-gold-marine-grade-stain-and-varnish-aerosol_p1580425
And the small wooden crates also when they are available
https://www.bunnings.com.au/ryobi-19-piece-metric-high-speed-steel-drill-bit-set_p0056805
https://www.bunnings.com.au/ryobi-50mm-6-piece-ph2-impact-diamond-driving-bit-set_p0436335
https://www.bunnings.com.au/ryobi-18v-one-drill-driver-starter-kit-r18dd22_p0715241
Follow the crates instructions
- Step 2:
design a shape of the shelfs as you like and screw them together and the joining points of two opposites flat side
- Step 3:
spray paint time
- Step 4:
repeat as many times for as many crates and how big you wanted it
- Step 5:
use anchors to mount to the wall
- Step 6:
decorate and fill in the shelf.
Note: I did add in fairy lights and flowers also found at Bunnings
- Step 7:
Note part 2: I used a spare piece of wood I had in the shed as a base as I miss calculate the tv stand
- Step 8:
Note 3:I have made a smaller one and I have also recently moved house and this time I could not put it on the wall but I still rearranged and have put it on the floor this time still love it and still use it as my tv stand also
