I have now pulled out the shelves and removed the existing doors and architraves from the cupboard that I am converting to a laundry.
After removing the door frame there are a couple of areas of plasterboard that need to be patched/repaired. I’ve watched so many repair videos that show different methods, I’m now not sure what method to use!
Photo 1: this joint was never taped as it was covered by the door frame. As the gap is approx 1cm in spots I’m wondering what the best method is to finish this.
Photo 2: the plasterboard edge has crumbled in spots and isn’t level with the interior plasterboard wall. I will be extending this out by about 12cm (probably by attaching a piece of timber) So I’m not sure whether to repair it first using an aluminium corner bead/trim, or just fill and patch as needed once the wood has been added.
Thanks
Tracy
