Hi there
I’d like to paint outside of this manual pull, wall mount screen projector the same colour as the wall (Dulux Ecru) so that it blends in visually.
What’s the best way to go about this?
I have plenty of wall paint – can I use this? Should I apply some kind of primer and/or finish for longevity?
The screen’s housing is mostly metal, with plastic sides.
The black rod on the bottom (that you pull down on), which I also want to paint, is also plastic. And the ring that you pull down on is metal.
Also, I plan to mount the screen over my patio door, like how you would with a roller blind. Am I ok to simply mount the projector directly onto wooden door frame with the two screws it comes with (roughly 3cm long)? The screen weighs 7.5kg.
