Simple to build and a great add to any yard. If kept in a square will be a easy project.
Merbau timer for rafters and posts. For the seats l have used besser blocks then merbau decking timber. Finishing off with roofing panels for the exterior and standard concrete pavers with crushed dust.
Level,string line,Drop saw or hand saw,nail gun, screws 100mm with impact drill,Jigsaw,
1 First set up a square measuring the required area.
2 Make sure your working from the outside perimeter and dig out each corner for your posts.
3 Concrete in your posts
4 Run a string line around the posts and screw your sleeper to the post. And make the sleepers continue around the outside of the post to form the square.
5 make the desired seat hight and depth same to match the sleeper hight and besser bricks.
6 Make the angle seating back supports tie it to cross timbers you put on the seats secure them to the besser block and sleepers screwing it all.
7 Cut and screw the decking to the seats.
8 Cut any form of rafter supporting the sides and roughly don't go smaller than 1200mm apart.
9 Cut the desired roof sheets to size and nail to besser blocks using gal 50mm nails.
10 Add crush dust and compact down and add your paving.
