Hi there
I've just taken off some old washing machine taps as I need something more low profile in order to fit a dryer on top of the washer.
Everything looks OK (I think), however, the fixtures on both sides have slow leaks. If you dry them, leave for a few minutes, and touch the bottom there will always be a little bit of water.
Hot tap is capped using:
Brasshards 15mm Brass Threaded Cap
Kinetic 15mm Tap Washer
Thread tape
Cold tap using:
Brasshards Chrome Plated Elbow
Brasshards Mini Washing Machine Tap 20mm
Thread tape
Any thoughts??
