Removed the old existing outdated gas fire place and created a stone feature wall with a new electric fire place, creating a warm modern entertaining feature wall and environment in our living room
90x45 timber to frame wall https://www.bunnings.com.au/90-x-45mm-framing-mgp10-untreated-pine-3-0m_p8030081?store=6299&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gbraid=0AAAAADtbEB8cy5pT_F8ymED1cs__CflDS
Cladding sheet board https://www.bunnings.com.au/james-hardie-3000-x-1200-x-6mm-3-6m-flex-cladding-sheet_p0711118
Tasmanian oak hardwood to make shelf x 4 https://www.bunnings.com.au/185-x-19mm-2-4m-dar-tasmanian-oak-select_p0070427?store=6425&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gbraid=0AAAAADtbEB8HKF8CMYV2uZo3oskFWk7os
Stone adhesive glue https://www.bunnings.com.au/dunlop-5kg-trade-resaflex-tile-adhesive_p6820186?store=6425&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gbraid=0AAAAADtbEB8HKF8CMYV2uZo3oskFWk7os
White washed sand (to create grout mix) https://www.bunnings.com.au/bastion-20kg-dried-sand_p0208298
White cement 20kg bag (to create grout mix) https://www.bunnings.com.au/australian-builders-20kg-off-white-cement_p0135870
1x 20kg bag hydrated lime ( to create grout mix)
https://www.bunnings.com.au/australian-builders-20kg-hydrated-lime_p0086148
Scandia electric fire 74” https://www.bunnings.com.au/scandia-74-aurora-electric-fire_p0411393
Wood stain for timber
https://www.bunnings.com.au/bondall-250ml-walnut-monocel-stain-and-varnish-250ml_p1580823
8sqm Stone cladding
Brick hammer https://www.bunnings.com.au/trojan-600g-steel-brick-hammer_p0131364
trowel https://www.bunnings.com.au/qep-6mm-square-notch-margin-trowel_p0393513
Grinder https://www.bunnings.com.au/ryobi-18v-one-115mm-angle-grinder-tool-only_p0509295
Ozito drop saw https://www.bunnings.com.au/ozito-2100w-254mm-10-corded-double-bevel-sliding-mitre-saw-scms-2125_p6290588
sponges https://www.bunnings.com.au/all-set-6-pack-jumbo-sponges_p0627036
foam brushes https://www.bunnings.com.au/uni-pro-4-piece-foam-brush-set_p1670850
Grouting gun
https://www.bunnings.com.au/trojan-pointing-grouting-gun-610mm_p0551235
we framed out our new fire place wall and added insulation and stone sheeting to the frame
we began sticking the stone cladding to the wall, piece by piece
we build the custom shelf and attached it to the wall
we Then began grouting the wall with our mixed sand and cement grout
once grouting was completed we then wiped the wall with our sponges to remove excess grout and allowed to dry
final step we then inserted the electric fire, mounted the shelf and mounted the new tv to our wall. And decorated the area to complete our feature wall in our living room
Hello @JordanH
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your stone wall fireplace project.
What a fantastic transformation! The difference between the before and after is remarkable. You've turned what was once an outdated fireplace into a stunning modern feature wall that completely elevates the living room. The stone cladding adds beautiful texture and warmth, while the sleek electric fireplace and floating timber mantel create a clean, contemporary focal point. The lighting above the stone really brings the whole design to life and makes the space feel warm, inviting, and perfect for entertaining.
Thank you for sharing both the materials you used and the steps you took to complete the project. It's always inspiring to see the journey from demolition through to the finished result, it really showcases the planning, craftsmanship, and attention to detail that went into the revamp. The finished space looks elegant, cozy, and incredibly welcoming. You should be proud of what you've created!
Hi Jordan!
That looks incredible!! 😍
I have the same old fireplace at the new home and I have been looking for ideas to renovate it!!
Finding a great electric fireplace just at Bunning! Make is to easy for sure I will Start planning this project soon! I got so much ideas!!
Well done! 🎉
Welcome to the Bunnings Workshop community @Kot. It's wonderful to have you join us and great to see you've enjoyed this project.
Let me tag @JordanH, so they are alerted to your comment.
Feel free to reach out if you need a hand with your project. We'll be looking forward to seeing what you achieve.
Thank you Kot and MitchellMc, more than happy to assist with any questions in regards to my project. Bunnings really does have it all for the D.I.Y
Looks brilliant @JordanH!
Thanks for sharing.
So cosy! Love it.
This is a beautiful wall Jordan! Thank you for sharing. I am planning to crate a similar wall behind a freestanding fireplace that will be installed later. I already got the sand stone cladding, do you know if the James Hardie 3000 x 1200 x 6mm 3.6m² Flex Cladding Sheet can take about 56kg/square meter? Or is there any other recommendation from Bunnings?
The cladding will be in an internal wall measuring 243 height by 164 width and the sand stone is about 56kg per square meter.
Thanks in advance.
Welcome to the Bunnings Workshop community @MaiaZaltron. It's wonderful to have you join us and great to see you enjoyed this project.
Let me tag @JordanH so they are alerted to your question. The only Hardie's product that is suitable for cladding or tiling over is Villaboard. For a carrying capacity of 56kg/square meter, you'd be looking at the 9mm Villaboard. It can carry up to a tile thickness of 18mm and 60kg/square meter if using 450mm spaced studs.
hi @JordanH. Your design looks great but I’m wandering if you removed your dining area with chairs and built a seperate wall as well. In the last picture 🤷♂️
