re done the kitchen and floor complete gut and redo as well as taking some walls out
used all kaboodle stuff for the kitchen (https://www.bunnings.com.au/kaboodle-38-x-901-1200mm-calcutta-gloss-single-square-edge-customisable-benchtop_p2683429)
And for the flooring I’ve used bunnings floor select blackbutt flooring (https://www.bunnings.com.au/floor-select-6mm-2-2m-blackbutt-hybrid-waterproof-flooring_p0135656)
even the splash back is tiles from Bunnings (https://www.bunnings.com.au/johnson-tiles-300-x-100mm-white-gloss-ceramic-wall-tile-white_p0012676)
came out perfect
I used all makita powertools
step 1 remove all the old kitchen and remove walls
- Step 2:
Step 2 re plaster where the walls were and paint everywhere
- Step 3:
Step 3 put in kitchen kicker making it completely level so the cabinets can sit straight on
- Step 4:
Step 4 place kitchen cabinets in and screw them all down
- Step 5:
step 5 put cabinet doors on
I used a sheet of mdf and cut the doors to size with my track saw since I had to customise the cabinet so use mdf and painted it the same as the Kaboodle colour
- Step 6:
Step 6 but bench top in gluing and clamping joins
- Step 7:
step 7 tile backsplash and grout
Tiling was interesting as that’s the first time I’ve ever tiled
- Step 8:
step 8 put flooring down and click them all together
- Step 9:
step 9 put all trims on and caulk everything
- Step 10:
Step 10 clean up and enjoy new kitchen
