floating timber shelves built into entryway. Was such a large area and needed some creativity!!
https://www.bunnings.com.au/gyprock-csr-75mm-x-3600mm-cove-plaster-cornice_p0730647
https://www.bunnings.com.au/gyprock-csr-2400-x-1200-x-10mm-2-88sqm-plasterboard-re_p0731415
https://www.bunnings.com.au/selleys-320g-liquid-nails-construction-adhesive_p1233751
https://www.bunnings.com.au/90-x-35mm-framing-mgp10-untreated-pine-2-4m_p8030056
https://www.bunnings.com.au/siniat-30-x-2400mm-90-external-angle-plaster-trim_p0730701
https://www.bunnings.com.au/gyprock-csr-5-5kg-acrylic-stud-adhesive_p0731172
https://www.bunnings.com.au/gyprock-csr-6kg-pre-mixed-cornice-cement_p0730670
Used timber screws and nails.
timber shelving was made from a kitchen bench piece. Cannot link as no longer available at Bunnings. Promo piece.
https://www.bunnings.com.au/hyde-152mm-plaster-joint-knife-tool-with-hammerhead_p0730298
https://www.bunnings.com.au/ozito-1600w-210mm-8-corded-compound-mitre-saw_p0025645
https://www.bunnings.com.au/ozito-pxc-18v-cordless-drill-and-impact-driver-px2pak-500-kit_p0299326
https://www.bunnings.com.au/builders-edge-55-75-x-90mm-mitre-box_p0730303
measure up and frame walls
I used liquid nails to attach to floor and screwed into existing walls
Add extra noggins for shelving at desired heights
Cut plaster board to size and apply with stud adhesive (apply internal sheets first, then screw in floating shelving)
Add corner angle and nail/screw plaster to timber frame and finish other side of walls
apply joint tape and plaster all joins
sand and replaster until smooth and flush
Cut cornice as per Bunnings guided video and apply using cornice cement. I tapped a couple of small nails in to hold in place (these are removed once dry)
Prime and paint!
then the best part!! Styling
