This project involved replacing an outdated wood burner fireplace that was over 20 years old, along with a 10mm fibro base and old pink tiles used for floor protection.
The original feature was no longer safe, efficient, or visually suited to the home. The goal was to modernise the space and increase the property’s value by creating a contemporary focal point.
Using Bunnings DIY products, we designed and built a combined fireplace TV unit with decorative cabinetry and integrated storage. The finished result has transformed the living area into a warm, stylish, and inviting central feature of the home.
2 x Kaboodle 600mm White Base Cabinet,
https://www.bunnings.com.au/kaboodle-600mm-white-base-cabinet_p2662611
2 x Kaboodle 600mm White Wall Cabinet,
https://www.bunnings.com.au/kaboodle-600mm-white-wall-cabinet_p2662262
Kaboodle
1 x 150mm White Infill Wall Cabinet - 150mm,
https://www.bunnings.com.au/kaboodle-150mm-white-infill-wall-cabinet-150mm_p2662256
1x Kaboodle 150mm Infill Base Cabinet - 150mm,
https://www.bunnings.com.au/kaboodle-150mm-infill-base-cabinet-150mm_p2662587
4 x Kaboodle 300mm Gloss White Heritage Medium Cabinet,
https://www.bunnings.com.au/kaboodle-300mm-gloss-white-heritage-medium-cabinet-door_p0464548
2 sets Mirabella 9W 750Lm RGBW IP44 1.2m Flex & Plug Genio Smart Wi-Fi Dimmable Downlight - 4 Pack,
https://www.bunnings.com.au/mirabella-9w-750lm-rgbw-ip44-1-2m-flex-plug-genio-smart-wi-fi-dimmable-downlight-4-pack_p0361945
For the Fireplace
All Timber products for the framing from the timber section.
All MDF products from the timber section.
The Mantle was from the timber section.
Paint for the Fireplace Enclosure was from Bunnings Paint Section.
For the Benchtop Custom Built Think Timber 32mm Ash Custom Made Benchtop,
https://www.bunnings.com.au/think-timber-32mm-ash-custom-made-benchtop_p2666189
- Ozito Battery Drill
- Ozito Battery Planer
- Electric AEG 115mm Skill Saw
- Paint Brush
- Phillips Heads Screw Tips
- Ryobi Drill Set
- Staley Fat Max 8m tape
- Stanley Level
- Painters Tape
- Concrete Wall Plugs
- Assorted Screw
- Masinsory Drill Bit
- Cornace and Skirting from Internal Timber Section
- Ozito Battery Nail Gun
Measure Out Space
Old Wood Burning Fireplace to be replace by Electric Fireplace, TV and Cabinets
- Step 2:
Build Framework for TV and Fireplace space
- Step 3:
Install Fireplace into Framing
- Step 4:
Cut and Frame MDF to enclose framework to fireplace and TV
- Step 5:
Wall and Base Cabinets installed
