I love updating these little pot cupboards, they have so much character and charm. I picked up this one for free on FB Marketplace and wanted to bring it back to life!
Easycraft VJ panel
Cabot's water-based stain and varnish
Cabot's Cabothane clear
BIN Shellac primer
Dulux paint
Sandpaper
4mm nap roller
Brad nails, staples
Wire mesh
AEG Orbital Sander
Ozito stapler nail gun
Jigsaw
Drill, screwdriver
Tape measure, pencil
I started by removing the handle, door and back plate, then used an orbital sander to remove the existing stain/varnish - working up from 100 to 250 grit sandpaper.
To cut out the door insert and reshape the door frame I used a jigsaw, before sanding the edges smooth with an orbital sander.
- Step 2:
To replace the damaged back I used an Easycraft VJ panel offcut, which I cut to size using a jigsaw, sanding the edges smooth.
I cleaned the piece thoroughly before applying primer/paint to the interior and stain/varnish to the exterior with a 4mm nap roller. Once dry I attached the new Easycraft backing with brad nails.
- Step 3:
For the door front I attached wire mesh to the inside with an Ozito staple gun, before refastening the original handle, which I cleaned and reused.
And here is the final result!
