Marrying a new outdoor entertaining area with our old verandah was a great project! Working hard at perfecting gaps and mitre joints for my first time! I fear I over-engineered this one, with more stumps, concrete and bracing then the existing house!
Here's a high-level list of the materials I used.
I already had a big bucket of stainless deck screws, I used stainless as I'm near the ocean here and it destroys all metal!
First job of any DIY build is to consult with your manager. We had to measure up, prepare to remove the clothesline and old garden bed.
- Step 2:
The trickiest part of a build like this (when you're not a pro!) aside from working around a Jack Russell, is marrying the existing structure to the new structure, so I did a lot of "measure twice, cut once…" (And some measure four times, cut twice…) But the stump digging started, revealing a pipe that needed to be moved.
- Step 3:
Post holes dug, roughly 800 deep, 400 out the top as the existing structure was quite close to the ground. I used a little gravel in the bottom of the post holes and I painted the ends of the posts where they would be in contact with soil. I also coated any surface that i'd cut, to help with the H4 treatment protection. After all of the posts were in place, I rolled out and pinned down weed mat to help stop weeds and grass growing up under the deck.
I also lost my marking pencil for AGES… THIS is where it turned up!
- Step 4:
Bearers bolted into the stumps, I cut out little shelves (checks?) for the bearers to sit in and used galvinised bolts to secure them. Then I set the joists in their rough positions to make sure everything was in its right place and that my levels were looking ok. (OH, and I did the weed met after THIS step, not the last one!)
As an aside, I found some handy tips in this article on the Bunnings website.
Oh, another non-pro tip: The knee protectors are gold! Choose the ones you like, but use them! Thank me later. (Check them out here)
- Step 5:
Missed a couple of photos here, but after my bearers were fixed in place, I laid in all of my decking boards and used 4mm deck spacers to make sure they were all equally spaced.
- Step 6:
After getting the deck all screwed down, we enjoyed a coffee in the morning sun and started work on the step! I'd chosen a corner step and am triggered by mitred corners that aren't level - it took lots of measuring to get everything in the right place! It's not 100% perfect, but close enough that I don't see the pieces out of line.
The forewoman checking level on my custom-length level! (I passed the test)
Having the step deck boards line up with the picture-framed mitred corner was a challenge! Youtube and the Bunnings website - great resources!
- Step 7:
All done and with one coat of finish (last photo), it will take a couple of sands and coats before the new pine starts to more closely match the older deck boards.
Last pro-tip: every job that doesn't require a dog, with a Jack Russell, has a dog.
