This is my offroad esky buggy/baby carrier custom made. Its for transporting my esky at 4wd events. Has a spot for a jbl speaker, makita battery for charging, headlights, tail lights and led whip lights. Flexes better than the comp rigs under its own weight. Custom bead lock rims. 3d printed light bar. So much work put into this thing its crazy and 95% made from bunnings gear
https://www.bunnings.com.au/metal-mate-25-4-x-1-2-3m-galvanised-steel-round-tube_p1130457
Frame
https://www.bunnings.com.au/saxon-254mm-pneumatic-wheel_p0336005
Wheels + custom bead locks
https://www.bunnings.com.au/goliath-185mm-100n-black-gas-strut_p4230023
Shocks for the coil overs
https://www.bunnings.com.au/century-spring-corp-22-x-101-6-x-2mm-compression-spring-2-pack_p0487994
Coils
https://www.bunnings.com.au/grunt-20mm-x-40cm-versa-strap_p0199267
Jbl speaker holders
https://www.bunnings.com.au/zenith-5-16-and-m8-rubber-washer-40-pack_p2420938
Rubber washers for the trailing arms
https://www.bunnings.com.au/pillar-16mm-x-3-0m-brushed-chrome-curtain-rod_p1284732
Trailing arms
https://www.bunnings.com.au/pillar-25mm-x-2-0m-brushed-chrome-curtain-rod_p1284738
Diffs
https://www.bunnings.com.au/makita-18v-3-0ah-battery-197599-5_p6240406
https://www.bunnings.com.au/makita-18v-usb-charging-adaptor-adp05-skin-only_p6240363
https://www.bunnings.com.au/ozito-23kg-portable-sandblaster_p6290557
Frame was filled with sand and bent up with a tube bender and welded
- Step 2:
Trailing Arms, diffs, steering knuckles, pull handle all custom made and welded up. Wheels taken apart and welded on imitation bead locks
- Step 3:
Made up custom coil overs out of gas struts and springs. Took the ends off the struts put big washers on to sandwich the springs and put the ends back on.
- Step 4:
Sand blasted all the parts and painted and reassembled.
- Step 5:
Wired up 3d printed min light bar, headlights , taillights and mini led whip lights to the makita battery.
- Step 6:
Install Esky or baby seat and jbl speaker
