Hi all,
I'm entertaining the idea of putting a Japanese dry garden on my apartment balcony. This would primarily consist of a ~5cm bed of gravel, specifically 10mm Crushed Western White*. I intend to rake the garden weekly or so.
My balcony has a tiled floor and I assume a waterproof membrane beneath, so I would like to avoid any damage to it. It also has a drain in the middle and two gaps in the balustrade, see pic below ⤵️
I have a few questions:
- What measures would I need to take to support the gravel bed?
- I did some googling and I've been suggested a layer of drainage cell + geotextile drainage mat, so that the gravel bed won't trap water against the tile and wear away the grout.
- What's the best way to join the drainage mat strips together? I assume there will be a lot of lateral movement (from walking over + raking the gravel)
- How should I go about blocking off the two wall gaps to stop gravel spilling off my balcony?
- Is there anything else I'm missing/I need to consider?
Thank you for taking the time to read this!
*I emailed Auburn Botanic Gardens to ask for the exact gravel they use for their own Japanese gardens.
