Complete DIY renovation of a run-down, barely functioning laundry. The original space had non-working sink plumbing, no usable storage or bench space, broken lighting and limited power options. The aim was to create a highly functional, inviting space for everyday use. Certified trades completed the in-wall plumbing and electrical, with all other work entirely DIY, learning as I went.
Dulux White Ceiling +PLUS Kitchen And Bathroom Paint - 1
Rapidset Repair Mortar
https://www.bunnings.com.au/dulux-4l-interior-paint-wash-wear-plus-kitchen-bathroom-low-sheen-vivid-white-4l_p1370128
https://www.bunnings.com.au/bastion-20kg-floor-leveller_p0273642
https://www.bunnings.com.au/bastion-15kg-under-tile-waterproofing-membrane_p0328253
Dunlop 100mm x 50m Waterproofing Reinforcing Mat
https://www.bunnings.com.au/bastion-20kg-mastic-powder-adhesive-tile_p0273639
Decor8 200 x 200mm Gabana Rubeli Matt Floor Tile
Benchtop – custom order laminate benchtop
https://www.bunnings.com.au/qep-3mm-cross-tile-spacers-100-pack_p6821850
https://www.bunnings.com.au/qep-xl-tile-levelling-wedge-250-pack_p1073326
https://www.bunnings.com.au/ramset-10-x-100mm-galvanised-ankascrew-masonry-anchor_p2260285
Splashback Subway Tiles
Skirting Tiles 300 x 600
https://www.bunnings.com.au/dunlop-5kg-flexible-coloured-grout-misty-grey_p6829808
Dunlop 250ml Grout Sealer
Kaboodle 64mm White Plaza Kitchen Handle
https://www.bunnings.com.au/carinya-140-x-40-x-40-x-2mm-hot-dipped-galvanised-reinforcing-angle-bracket-140-x-40-x-40-x-2mm_p0046918
Light shade - Bunnings (old stock item)
https://www.bunnings.com.au/estilo-stainless-steel-single-bowl-sink_p0300753
Gooseneck Mixer tap
https://www.bunnings.com.au/practa-80cm-wall-mount-foldaway-clothes-rack-with-5-rails_p0749931
https://www.bunnings.com.au/ozito-1500w-5j-rotary-hammer-drill-kit-rhd-1550_p0382377
Kanga Angled Tiling Chisel:
https://www.bunnings.com.au/kango-75mm-x-170mm-sds-plus-angled-tiling-chisel_p0354387?store=5150&gclsrc=aw.ds&gad_source=1&gad_campaignid=21118986128&gbraid=0AAAAADtbEB_W67YyeFBljqPyt3z8BSeG7&gclid=EAIaIQobChMI-7-vpvS3lQMV6s08Ah3xwiDsEAQYASABEgJWovD_BwE
Ozito Jigsaw:
https://www.bunnings.com.au/ozito-680w-pendulum-jigsaw-with-3-blades-jsw-6800_p6290651?store=5150&gclsrc=aw.ds&gad_source=1&gad_campaignid=21118986128&gbraid=0AAAAADtbEB-bAcnNbyUD1Ob3fBDIgVp7k&gclid=EAIaIQobChMIuqjb96ixlQMVB-YWBR3yqzkzEAQYAiABEgIGXfD_BwE
https://www.bunnings.com.au/lasertec-cx4dg-dot-crossline-laser_p0135917
https://www.bunnings.com.au/ozito-pxc-18v-impact-driver-skin-only_p6290472
https://www.bunnings.com.au/ozito-125mm-5-angle-grinder-kit_p0048825
https://www.bunnings.com.au/flexovit-125mm-diamond-multi-blade_p6370870
Tile Cutter - hired from Bunnings Hire Shop
https://www.bunnings.com.au/products/hire-shop?gclsrc=aw.ds&gad_source=1&gad_campaignid=19898944941&gbraid=0AAAAADtbEB_HjGNINLjKC3M0KF3XU3fJU&gclid=EAIaIQobChMImaT8gvS3lQMV4hWDAx1AxjANEAAYASAAEgIH6fD_BwE
STEP 1 – PLANNING
BEFORE: Broken timber window (no flyscreen, stuck winder, poorly fitted glass), non-functional sink plumbing, incorrectly sloped floor, broken light fitting, limited power, no usable storage or bench space, and wall and ceiling imperfections.
DESIGN BRIEF: To create a highly functional, modern laundry that improves practicality for everyday life.
- Measured the space, finalised the layout, and ordered all materials in advance to minimise delays.
- Step 2:
STEP 2 – DEMOLITION
- Removed all existing fixtures and cabinetry.
- Removed the old window.
- Demolished floor tiles using an Ozito rotary hammer drill with tile chisel bit, ensuring all old adhesive was fully removed.
- Step 3:
STEP 3 – LEVELLING
- Patched wall chasing from new plumbing work using Rapidset Mortar Repair.
- Installed new custom-order aluminium window.
- Re-levelled floor using Bastion Floor Leveller, ensuring adequate fall so water drains properly to the existing floor waste.
- Step 4:
STEP 4 – PAINTING & FLOOR TILING
- Painted ceiling & walls with Dulux Bathroom & Kitchen Paint (suited for higher humidity spaces)
- Waterproofed floor and sink surround, reinforcing corners and allowing full drying time between coats.
- Dry-laid tiles to confirm spacing and cuts
- Cut tiles using Ozito Angle Grinder with diamond cutting blade, and a tile cutter from the Bunnings Hire Shop.
- Laid and grouted all floor tiles
- Step 5:
STEP 5 – CABINETRY INSTALL
- Installed upper cabinets using rail install system, laser level and Ramset Masonry anchors, ensuring adequate clearance space between cabinet and future benchtop.
- Installed timber and galvanised bracket supports for benchtop
- Step 6:
STEP 6 – BENCHTOP & SINK INSTALL
- Installed lower cabinets
- Installed custom benchtop
- Cut sink opening using Ozito Jigsaw and supplied sink template
- Installed sink using included mounting system
- Step 7:
STEP 7 – SPLASHBACK TILING
- Tiled splashback using spacers and laser level for alignment
- Cut tiles as required using angle grinder with diamond blade
- Step 8:
STEP 8 – GROUTING
- Grouted splashback
- Measured, cut and installed skirting tiles around the room perimeter
- Sealed all grout once fully cured
- Step 9:
STEP 9 – AIRER INSTALL
- Installed fold-out wall-mounted clothes airer
- Installed new tapware (completed by certified plumber)
- Step 10:
STEP 10 – FINAL INSTALLS
- Installed new light fitting (electrical completed by licensed electrician)
- Installed floating shelves, hooks, handles, appliances and decorative elements.
