πΌοΈ
A month-long DIY project involving 50+ trips to Bunnings, this custom chicken coop was built to keep the chickens safe while giving them the freedom to come and go through an automatic opening and closing door. It combines security, practicality and a touch of obsession. Every detail was built by hand to create a safe and happy home
Materials Used (mostly from Bunnings):
H3 treated pine timber
Colourbond corrugated roofing sheets
Roof flashing / edge capping
Roof and gutter silicone
Aluminium sheet
Galvanised roofing screws
Timber screws (various sizes)
Bugle batten screws
Coach screws/bolts
Construction adhesive (Liquid Nails)
Galvanised brackets and angle brackets
Door hinges
Polycarbonate roofing screws with rubber washers
Exterior paint or timber sealer
Bunnings Departments:
Timber β Building Materials
https://trade.bunnings.com.au/70-x-35mm-framing-mgp10-untreated-pine-2-4m_p8030010
Roofing sheets & flashing β Roofing
Silicone β Paint & Building Sealants
Screws & brackets β Fasteners & Fixings
Aluminium sheet β Metal Sections & Sheets
Wire mesh β Garden Fencing
Hinges & latches β Door Hardware
Construction adhesive β Adhesives & Sealants
https://trade.bunnings.com.au/selleys-350g-heavy-duty-construction-adhesive-3-pack_p1210574?utm_source=chatgpt.com
Tools Used:
Cordless drill/driver
Impact driver
Circular saw
Mitre saw (drop saw)
Jigsaw
Angle grinder (metal cutting)
Multi-tool (oscillating tool)
Hammer
Tape measure
Spirit level
Clamps
Tin snips (for flashing and aluminium)
Caulking gun
Screwdrivers
Utility knife
Wire cutters
Pliers
Ladder
Paint brushes and rollers
-Plan the palace β Design a safe, practical home fit for some very lucky chickens.
-Hit Bunnings... repeatedly! β Make 50+ trips collecting timber, Colourbond, screws and everything else needed.
-Build the frame β Construct a strong timber structure from the ground up.
-Clad it in Colourbond β Install the walls and roof for a durable, weatherproof finish.
-Fit the automatic door β Give the chickens VIP access with a door that opens at sunrise and closes at sunset.
-Weatherproof everything β Install flashing, silicone and trims to keep the coop dry year-round.
-Add the finishing touches β Fit perches, nesting boxes and make sure every detail is just right.
-Welcome the flock home β Sit back and enjoy watching the chickens settle into their custom-built mansion.
