ripped out old pantry shelving and replaced with draws shelving and a bench top to make it more of a coffee nock and not have to clutter bench top in kitchen with appliances when cooking
Kaboodle 900mm White Base Cabinet
https://www.bunnings.com.au/kaboodle-900mm-white-base-cabinet_p2662244
Kaboodle 900mm White 3 Drawer Base Cabinet
https://www.bunnings.com.au/kaboodle-900mm-white-3-drawer-base-cabinet_p2662253
Bench top was Specrite Brown Acacia Multi Use Panel
https://www.bunnings.com.au/specrite-1800-x-600-x-18mm-brown-acacia-multi-use-panel_p0446743 shelving was made from CUSTOMwood 2400 x 1200 x 3mm Raw Standard MDF E0
https://www.bunnings.com.au/customwood-2400-x-1200-x-3mm-raw-standard-mdf-e0_p0590021
Shelving framed out with 42 x 19mm 1.8m DAR Pine Premium - 1.8m
https://www.bunnings.com.au/42-x-19mm-1-8m-dar-pine-premium-1-8m_p8401457
circular saw -makita 18v
https://www.bunnings.com.au/makita-18v-165mm-brushless-circular-saw-dhs680z-skin-only_p6240314
nail gun ozito
https://www.bunnings.com.au/ozito-pxc-18v-cordless-2-in-1-cordless-nail-and-staple-gun-pxngs-018-skin-only_p0136008
tape measure
https://www.bunnings.com.au/crescent-lufkin-shockforce-nite-eye-5m-x-30mm-tape-measure_p0671733 There was an error displaying this embed.
combination square
https://www.bunnings.com.au/empire-300mm-combination-square_p5667081 There was an error displaying this embed.
hammer
https://www.bunnings.com.au/trojan-20oz-framing-steel-hammer_p0492158
Level
https://www.bunnings.com.au/stanley-fatmax-900mm-3-vial-beam-spirit-level_p5660135
https://www.bunnings.com.au/zenith-10g-x-50mm-gold-passivated-type-17-countersunk-head-timber-screws-50-pack_p2409143 There was an error displaying this embed.
Shopped for all supplies and tools ripped out old pantry
Built draws and cabinet then put into place used old kick boards
Cut bench top to size and placed in
Relocated existing PowerPoints to suit new space
repainted and patched up walls measured walls and decided on measurements for shelving started framing up shelves with pine 42x19 And sheeted with mdf
no more gaps and then painted the shelves
Add more shelving up the top with same material and process Then the final step added in the coffee machine
Hello @mellyB
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your pantry revamp project.
What a clever and practical transformation! Replacing the old shelving with drawers, generous storage and a dedicated benchtop has completely changed the pantry into a space that works so much harder. Turning it into a coffee nook and appliance garage is a brilliant idea that keeps the main kitchen benches clear while making everyday essentials easy to access.
The finished result is beautifully organised, functional and stylish, showing how a thoughtful redesign can make a big difference to the way you use your home. It's the kind of upgrade that will make daily life easier while looking fantastic at the same time.
Again, thank you for sharing such a wonderful project.
