An old concrete laundry tub sitting in our garden inspired this Upcycled, budget friendly, under house mudroom/laundry. This was the final area of our home needing a much needed freshen up to complete our renovation and there was not a large budget remaining to commence! With the massive help of our local Bunnings and some left over plumbing supplies including sink mixer and toilet, this area is now a useful, easily accessible & functional utility room for our busy family of five plus two large dogs!
Merbau bench top - Bunnings - used for bench and shelves
https://www.bunnings.com.au/specrite-2200-x-600-x-26mm-multi-use-merbau-panel_p8330163
Kaboodle Cabinet doors - Bunnings
https://www.bunnings.com.au/kaboodle-450mm-gloss-white-modern-cabinet-door_p2664585
https://www.bunnings.com.au/kaboodle-600mm-gloss-white-modern-cabinet-door_p2662511
Timber framing for cabinetry frame ( able to take the weight of laundry tub) - Bunnings
https://www.bunnings.com.au/70-x-35mm-framing-mgp10-h2-blue-pine-5-4m_p8030963
Concrete clear sealer for laundry tub - Bunnings
https://www.bunnings.com.au/crommelin-1l-diamondtough-stone-shield-clear-sealer_p1560547
White Knight Squirts Black Spray paint for metal window frame paint - Bunnings
https://www.bunnings.com.au/white-knight-310g-black-satin-squirts-spray-paint_p1560602
Satin sealer for Merbau Bench top
https://www.bunnings.com.au/cabot-s-1l-satin-water-based-cabothane-clear-polyurethane_p1522384
Dulux Paint - Bunnings
https://www.bunnings.com.au/dulux-4l-aquanamel-semi-gloss-white-enamel-paint-4l_p1400051
https://www.bunnings.com.au/dulux-interior-paint-wash-wear-semi-gloss-vivid-white-4l_p0638833
Dulux Textured Paint - Bunnings
https://www.bunnings.com.au/dulux-4l-fine-texture-exterior-paint-4l_p1409786
Matt black accessories from Bunnings including towel hooks, toilet roll holder, toilet brush
https://www.bunnings.com.au/pinnacle-50mm-matte-black-hanging-hook_p0184804
https://www.bunnings.com.au/caroma-matte-black-cosmo-toilet-roll-holder_p0130092
Basket planter for toilet paper storage - Bunnings
https://www.bunnings.com.au/390-x-300mm-extra-large-natural-woven-planter_p0426671
Ozito Paint Sprayer - Bunnings
https://www.bunnings.com.au/ozito-pxc-18v-paint-spray-gun-pxsgs-018-skin-only_p0738788
Ryobi Water Blaster
https://www.bunnings.com.au/ryobi-2465-psi-high-pressure-washer_p0637295
Ozito drill and driver
https://www.bunnings.com.au/ozito-pxc-18v-cordless-drill-and-impact-driver-px2pak-500-kit_p0299326
Paint rollers
Paint brushes
Hand tools - Bunnings
Screws Nails & fixings - Bunnings
Refurbishing & re-purposing concrete tub found in garden using Bunnings tools and materials - Bunnings water blaster, sandpaper, sealant. Inspo for this project.
- Step 2:
Clear out room and prep for painting throughout - ceiling with vivid white Dulux using Ozito Spayer. Walls with Wash n Wear vivid white painted on top of Dulux Fine Textured Paint to cover Bessa Block. Black Spray paint to freshen up tired old aluminium window slider.
- Step 3:
Built and installed Bunnings framing to retro-fit heavy concrete laundry tub and Kaboodle cabinet doors.
- Step 4:
Using 2400mm pre-made Merbau slab from Bunnings; build, fit and seal for the
benchtop. Use off cut for shelves.
- Step 5:
Paint timber frame using Dulux Vivid White Semi-Gloss and fit the white Kaboodle cabinet doors.
- Step 6:
Prep for tiling (re-purposed tiles from previous Reno) using Bunnings outdoor vacuum plus
all Bunnings tiling products including concrete fillers, tile glue, grout, trough, knee pads, buckets and sponges
- Step 7:
Re-purposed toilet plumbed in then added in all Bunnings Matt Black accessories including black round mirror, black towel hooks, black shelving brackets, black toilet roll holder, black toilet brush, basket water hyacinth
planter for toilet rolls
