I've built a external pedestrian timber gate and I need advice on the best type of hinges to use.
Ideally, I want to have the front face of the gate sitting perfectly flush with the face of the posts. The issue is that my gate frame is only 54 mm thick, while the posts are 88 mm thick. Because of the 34 mm difference I can’t simply mount a standard butt hinge to the back of both the gate and the post - as the face of the gate then sits 34mm back from the face of the post.
I also don’t want hinges mounted on the front of the gate, they should be hidden on the side or rear.
Is there a particular type of hinge that will achieve this look, or is the correct solution to recess the hinges into the back of the post so the pivot point sits in the right position for the faces to be flush?
I’ve digitally sketched it up with strap hinges to try and understand it all visually but I’m struggling so I could be missing the bleeding obvious here - apologies!
If anyone has had the same issue I’d really appreciate some advice or photos of how you solved it.
Cheers
