Hi team! Appreciate this forums existence, it's helped me as I fix our new home.
Previous homeowner did a bit of patchwork above the window. There was an air conditioning unit here which has been removed when ducted was put in and the hole repaired, but unlike the living room, this work (in the dining room) leaves a lot to be desired. Part of the patchwork is uneven, and it looks like they filled a large area.
I was thinking of either sanding (and/or chiseling given the amount) back the excess and filling it (then sanding again) to flatten the area out before we paint it in August.
I was also considering cutting the area out completely and replacing it with a new square of gyprock.
Which option is better long term? Is there an option 3 I am not aware of?
