Classic arcade machine running over 9000 retro games in a custom made MDF cabinet. Built from scratch in my shed.
Vinyl wrapped in a design I made for our favourite footy team! Go Pies!!
MDF SHEET:
https://www.bunnings.com.au/18mm-mdf-panel-standard-2400-x-1200mm_p0590060
TREATED PINE BATTENS:
https://trade.bunnings.com.au/42-x-42mm-1-2m-dar-square-general-purpose-pine_p0021181?srsltid=AfmBOorim8yz-SB_Dn220ZgjaMItIskZk4gGDAclLsrGPpxE_YBneOBkX-4
TIMBER SCREWS:
https://www.bunnings.com.au/zenith-8-10-x-40mm-treated-pine-countersunk-head-screws-100-pack_p2400008
ACRYLIC SHEET:
https://www.bunnings.com.au/suntuf-900-x-600-x-5mm-clear-acrylic-sheet-clear_p1010490
CASTER WHEELS:
https://www.bunnings.com.au/move-it-75mm-50kg-black-rubber-swivel-plate-castor-with-brake_p3940319
MDF PRIMER:
https://www.bunnings.com.au/dulux-500ml-1step-prep-primer-sealer-undercoat_p1370231?store=6075&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gbraid=0AAAAADtbEB9dZrHICs9_5njGnr2NAVZ81&gclid=CjwKCAjwgajSBhBEEiwASicJU8tqcUQLGEf6HaKeE1NZxpK9Oin8ZkX2WIDSVbLcg1YE3UVXsRzbtRoCvboQAvD_BwE
BLACK PAINT:
https://www.bunnings.com.au/british-paints-4-seasons-black-low-sheen-exterior-paint-1l_p0207105
20 INCH MONITOR, T MOULD, MINI PC, AMP, SPEAKERS, SPEAKER WIRE, JOYSTICK & BUTTONS, VINYL WRAP
MAKITA JIGSAW:
https://www.bunnings.com.au/makita-18v-brushless-jigsaw-djv184z-skin-only_p0370869
MAKITA CIRCULAR SAW:
https://www.bunnings.com.au/makita-18v-165mm-brushless-circular-saw-dhs680z-skin-only_p6240314
MAKITA DRILL:
https://www.bunnings.com.au/makita-18v-brushless-heavy-duty-compact-hammer-driver-drill-dhp484z-skin-only_p6240408
MAKITA DRIVER:
https://www.bunnings.com.au/makita-18v-impact-driver-dtd152z-skin-only_p6240335
Measure and cut two identical side panels. Install timber battens to support horizontal panels for top and bottom, shelves, keyboard and screen.
- Step 2:
Measure and cut all front and back, top and bottom and internal panels. Use the installed timber battens to screw from the inside and hide all the screws!
- Step 3:
VERY CAREFULLY measure and cut holes in the panels for the screen and speakers to be installed into.
- Step 4:
MDF always needs to be primed before painting or wrapping. So two coats of primer and then two coats of black paint.
- Step 5:
Design a cool wrap and find someone local who can print it for you!!
- Step 6:
Take 3847294842 years to slowly install wrap - making sure to push out any bubbles and creases!! Also, install T-mould around the edges for that really pro finish
- Step 7:
Install joystick and buttons, speakers and screen, and internal components and wire it all together.
It should be starting to look pretty flash!
- Step 8:
Good luck trying to get a go on it!!
