Caroma cistern running into bowl
Welcome to the Bunnings Workshop community @Nitram24. It's amazing to have you join us and many thanks for your question on fixing a leaking toilet.
A toilet that is continuously running into the bowl is usually caused by one of two things.
The first is a worn or damaged outlet valve washer. Over time, the rubber washer can harden or become damaged, preventing it from sealing properly and allowing water to slowly leak into the bowl.
The second common cause is the inlet valve. If it's not shutting off correctly or is set too high, the cistern can overfill and continuously run into the overflow, which then drains into the bowl.
I'd recommend removing the cistern lid and checking whether the water level is reaching the overflow tube. That will help determine whether the issue is with the inlet valve or the outlet valve washer.
This guide on How to fix a leaking toilet walks you through the most common causes and repairs, and should help you diagnose the problem:
Please remember that any plumbing work should be carried out by a licensed plumber where required by your local regulations.
Let me know if you have any questions.
