hello,
My shower door top trim closer mechanism has fallen out of it closing Device. I’ve been searching for its particular name and replacement but can’t find anything.
Are you able to assist if this can be fixed or replaced?
Hi @Stevehuynh,
I'm not too sure what the part you are looking for is based on this photo alone. Is there a piece that is missing? If so, do you have a photo of the piece that has fallen out?
I'd say it is fairly likely that it is a proprietary part that is specific to your shower screen and would need to be ordered as a spare part. If it is a product that Bunnings sell, we could certainly check with our Spare Parts team to see if it is something we can order.
To do this however, we would need to identify the shower screen.
Is there any identifying marks on your shower screen, such as a brand name or serial number? On the hinge, the shower frame itself or maybe even the handle?
Could we possibly get some more photos showing the whole shower screen? A close up of the hinges could also help.
Let me know what you find.
hi Jacob
It would be this part.
It’s magnetic and would just attach up when the door is closed but in the case it’s now in two separate pieces
when it’s closed the to piece would sit inside the other piece
So, it is essentially a magnetic catch that is specific to your shower frame.
Unfortunately, it is likely a proprietary part that could only be sourced through the manufacturer of the shower screen. If you were looking for a replacement, the only way would be to work out the manufacturer.
Has the magnetic part snapped off the piece on the door and is stuck to the top of the frame?
If it has snapped, you could try using some plastic glue to repair it.
Let me know what you think.
