We created a feature wall for our living room by smashing tiles into pieces and freehand placing them to create a unique pattern.
Travertine tiles - https://www.bunnings.com.au/duratile-60-x-60cm-travertine-natural-porcelain-floor-carton-of-3_p0271131
Grout - https://www.bunnings.com.au/dunlop-15kg-mid-grey-wide-joint-grout_p0508303
Glue - https://www.bunnings.com.au/dunlop-2kg-wall-and-floor-tile-adhesive_p6829353
Grout float - https://www.bunnings.com.au/qep-home-pro-grout-float_p6659942
Bucket - https://www.bunnings.com.au/bunnings-20l-pail-bucket-bucket_p0138319
Tile glue spreader - https://www.bunnings.com.au/qep-6mm-square-notch-plastic-adhesive-spreader_p6821486
Mallet - https://www.bunnings.com.au/craftright-32oz-rubber-mallet_p5560159
Gloves - https://www.bunnings.com.au/trojan-large-utility-gloves-large_p0282908
Sponge - https://www.bunnings.com.au/all-set-6-pack-jumbo-sponges_p0627036
Clean the wall
Smash tiles into smaller pieces and sort into sizes
Glue tiles in tessellating pattern starting from a corner. Use spacers to maintain gaps.
Mix grout in Bucket and apply to gaps with float.
Use a clean wet Sponge to wipe away excess grout from edges of the tiles.
Welcome to the Bunnings Workshop community @laurendavis88 and thank you for sharing your project.
This looks fantastic. The freehand layout gives it such a unique, organic look, and the mid-grey grout works really well with the travertine tones.
I like that you’ve broken the process down into simple steps too. Starting from a corner and sorting the tile pieces by size sounds like a great tip for keeping the pattern manageable as you go.
Congratulations on a wonderful project. I'm sure you love seeing it in your home every day.
