š¼ļø
our biggest challenge was a total lack of storage and a rapidly growing mountain of kids toys, games, and accumulated clutter. We needed a clever way to hide the daily chaos without sacrificing style. By installing seamless flat pack base cabinets and open shelving against VJ paneling, we created the ultimate secret weapon for quick cleanups. Now all the kids mess is instantly hidden behind closed doors, leaving us with a sophisticated, modern feature wall. It looks like a high end luxury lounge room, but itās secretly just our genius survival strategy for family life.
Best Invention ever https://www.bunnings.com.au/builders-edge-altamonte-mitre-template-plaster-tool_p0730322
Flat Pack Base Cabinets
Open Shelving Units
Acoustic Wall Paneling Sheetshttps://www.bunnings.com.au/specrite-2700-x-600-x-21mm-black-oak-timber-acoustic-panel_p0455961
Table Top https://www.bunnings.com.au/specrite-1200-x-600-x-18mm-timber-multi-use-pine-panel_p0419619
Timber Mouldings
Wood Trim
Gyprock Cornice https://www.bunnings.com.au/gyprock-csr-90mm-x-3600mm-cove-plaster-cornice_p0731300
Cornice Adhesive https://www.bunnings.com.au/gyprock-csr-20kg-cornice-cement-60_p0731164
Cabinet Door handleshttps://www.bunnings.com.au/taskmaster-96mm-matte-black-1-2-round-handle-10-pack-96mm_p0132785
Best primer ever https://www.bunnings.com.au/zinsser-b-i-n-primer-sealer-stain-blocker-white-3-78l-3-78l_p1565677
Paint https://www.bunnings.com.au/dulux-2l-renovation-range-cabinet-doors-satin-white_p0116477
Selleys Liquid Nailshttps://www.bunnings.com.au/search/products?page=1&q=selleys+liquid+nails&sort=BoostOrder
Wood Fillerhttps://www.bunnings.com.au/timbermate-250g-white-wood-filler_p1560677
Cordless Drill
Circular Saw
Hand Saw
Jigsaw
Spirit Level
Tape Measure
Sandpaper/sander
Sanding Block
Caulking Gun
Paint Brushes
Paint Roller
Paint Roller Tray
Drop Sheets
Gyprock Screws
Plasterboard Screws
Wood Screws
Isn't this how every DIY starts? Most start with a sketch on paper but...we started with a sketch on the wall
Because apparently the logical order of a DIY projectiss to buy the TV first...then panic and design around it. š The TV came home before the vision was fully formed, but it quickly became the inspiration for creating something custom and practical
Assembled the flat pack base cabinets and set them in position along the lower section of the wall.
Every DIYer knows this momentā¦when the room is a disaster, tools are everywhere and you question your life choices. But this is also the stage where the magic starts happening.
Installed timber spacing blocks between the base cabinets, screwed them together, and used wood filler to seamless the gaps so they appeared as one solid unit.
Double layered the horizontal shelves using liquid nails
positioned open upper shelving units on top of the base benchtop, and securely screwed them into the wall studs. Added marble contact over the table top
Cut and fitted custom timber filler pieces down the outer sides of the shelving units to flush them completely to the side walls, filling any gaps with wood filler.
Used wood filler to blank out all the pre drilled adjustable shelf peg holes inside the cabinet carcasses for a clean custom look.
Sanded down all of the dried wood filler, joints, and timber surfaces across the entire unit to prepare them for finishing.
Cut and installed the cornice along the top of the upper cabinets to give it an inbuilt look.
Primed all the cabinetry surfaces with an undercoat, applied the final coats of paint, installed the acoustic feature paneling sheets, and mounted the decorative world map. The hardest bit was the door handles š š¤£
If youre wondering about the order of this build or the instructions Ive posted⦠so am I. š
Thanks to ADHD, this project didnāt exactly follow a traditional step by step process. I skipped ahead, came back to unfinished parts, started three jobs before finishing one, and probably spent more time searching for the āperfectā tool than actually using it.
Organisation wasnt always part of the plan⦠and honestly, neither was having a plan at the beginning.
But thats the beauty of DIY .. creativity doesnāt always happen in a straight line. Sometimes itās a bit messy, a bit unpredictable, and full of problem solving along the way.
The moral of the story: you donāt need a perfectly organised workshop to build something amazing. You need a vision, a bit of questionable confidence, a Bunnings sausage for fuel, and the determination to eventually find the tool you were convinced someone stole. š
