We wanted to add a bit of character and create a focal point in our living room. Prior to this transformation, this was a long, blank wall that felt unfinished. By incorporating texture, contrast and a custom feature wall, we’ve created a space that feels warm and inviting.
90x45 H3 treated pine from Bunnings for the frame,
https://www.bunnings.com.au/90-x-45mm-framing-mgp10-h2-blue-pine-2-4m_p8031022?store=2016&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gbraid=0AAAAADtbEB9c1SzXFmpkFZk5ycrYp_tEx&gclid=CjwKCAjwpK3SBhASEiwAtV1SPKOtgESCOBpUuFBIv_gzYCBl8DA_SwRjvERIwL8AlNlXOjNQ4GBJzRoCDjAQAvD_BwE
We then installed gyprock CSR
https://www.bunnings.com.au/gyprock-csr-2400-x-1200-x-10mm-2-88sqm-supaceil-plasterboard-re_p0733386
Gyprock Joint Compound
https://www.bunnings.com.au/gyprock-csr-4-5kg-less-mess-multi-purpose-joint-compound_p0173347
Set and Prep Dulux Brand (Bunnings)
Concrete Look Design Paint
https://www.bunnings.com.au/dulux-4l-design-concrete-effect-paint_p1400923
Pine Panels
https://www.bunnings.com.au/12-x-133-x-2700mm-primed-fj-pine-general-purpose-portaline-vj-regency_p0497563
MDF Geometric Panelling
https://www.bunnings.com.au/hume-92-x-18mm-5-4m-dar-white-mdf-primed_p8470038
Fireplace
https://www.bunnings.com.au/scandia-50-aurora-electric-fire_p0411392
https://www.bunnings.com.au/makita-18v-brushless-heavy-duty-compact-hammer-driver-drill-dhp484z-skin-only_p6240408
https://www.bunnings.com.au/ryobi-1500w-184mm-corded-circular-saw-rcs1500-g_p0013549
Paint Brushes, Roller
After measuring and marking the wall, we began installing the frame that would form the structure of the media wall. This set the layout and dimensions. We ensured we measured the fireplace and TV to ensure there was enough space in the framing.
- Step 2:
Once framing was complete, we added gyprock sheeting followed by joint compound.
We then sealed the wall with 4 in 1 Prep Sealer.
All products purchased from Bunnings.
- Step 3:
We then began the paint process, We wanted a concrete look.
We used the Dulux Design Concrete effect paint
This required three coats and a steal trowel to achieve the concrete look.
- Step 4:
We added tongue and groove pine panelling to one side and primed MDF boards to the other side to achieve a geometric design
We then added black Matte Paint
The completed project included the Scandia 50" Aurora Electric Fire available to purchase from Bunnings.
