This was just a storage room & corner sink in a 1970’s house, laundry was located outside.
Completed all the framework, plumbing, electrical (electrician), flooring, cabinets and bench tops.
- Smartex pex fittings & pvc plumbing pipe
- Holman pvc pipe
- Taps & fittings
- Mirabella downlights
- Deta PowerPoints & switches
- Floor select hybrid flooring
- VJ style doors
- Privacy door sets
- MDF primed Door jambs
- MDF primed architraves
- Laminate quad
- Floor underlay with foil backing
- 10mm plaster, corner beads, tape, collated screws and compounds
- Cromellin waterproofing
- Mapei floor self leveller
- 100mm 2700mm x 1200mm VJ panel
- Flat pax cupboards & kaboodle bench tops
- Dulux wash and wear paint
- Roller trays, brushes and all paint accessories
- Caulking & silicon
- General hand tool
- Drop saw
- Levels
- Paslode nail gun
- Collated screw gun
- Planer
- Sander
- Flooring tool set
- Drill
- Impact driver
- tape measure
- Demolition of existing areas
- Planning of layout
- Framing of area to layout including ceilings
- Services roughed in
- Levelling of walls
- Plastered and VJ panels installed
- Areas prepped and sanded
- Areas painted
- Floor leveller then floors installed
- Cupboards ordered
- Cupboards put together and installed
- Bench tops installed
- Fixtures and fittings installed
