Outdoor Makeover! We transformed our outdoor area by adding a DIY concrete block pool. The project took 9 months. Engineer drawings and building approval was sought prior to commencement, House and boundary was chemically injected prior to dig.
Bunnings Buckets
Wheel Barrow
https://www.bunnings.com.au/sherlock-100l-home-use-steel-tray-wheelbarrow_p0043705
Shovels
https://www.bunnings.com.au/saxon-post-hole-long-fibreglass-handle-shovel_p0242871
https://www.bunnings.com.au/brighton-masonry-390-x-190-x-140mm-full-besser-block_p1180260
https://www.bunnings.com.au/specrite-1800-x-600mm-pre-oiled-merbau-garden-fence-panel_p8500298
Waterproof corners
https://www.bunnings.com.au/crommelin-270-external-corner-flexible-reinforcing_p0356883
Plants
https://www.bunnings.com.au/12l-magnolia-teddy-bear-magnolia-grandiflora_p3723866
https://www.bunnings.com.au/120mm-bird-of-paradise-strelitzia-nicolai_p0492903
https://www.bunnings.com.au/mondella-250mm-matte-black-rococo-square-shower-head_p0876562
https://www.bunnings.com.au/mondella-matte-black-lead-free-overture-shower-wall-mixer_p0696343
PVC Pressure Pipes
https://www.bunnings.com.au/holman-15mm-x-1m-pvc-pressure-pipe-class-18_p4750046
PVC Pipe Glue
https://www.bunnings.com.au/protek-500ml-type-p-green-pvc-cement-for-high-pressure-pipes_p3140035
It all began with a hand dig using wheelbarrows, shovels and buckets. As this was a DIY project the dig took roughly 2 months.
Next we completed the walls using Besser blocks before they were core filled.
At this stage piping was added, electrical work and earting was completed by a certified electrician.
The walls were then rendered and waterproofed.
Pool was then tiled with mosaics.
To complete the project we added an outdoor shower and plants Back wall was painted to complete the look.
Hello @TOS
What an incredible outdoor transformation! The finished pool area looks like a private resort, with the sleek concrete pool, stylish outdoor shower and thoughtfully chosen plants creating a beautiful space to relax and entertain. It's a fantastic DIY achievement that has completely elevated the backyard.
Thank you for sharing tis amazing project.
