Hi folks. Back for more advice. I am gonna try help someone sort this bathroom but have never done tiling before. Assuming this cracking and crazing is probably caused by moisture (and possibly movement).
I don't need it to be 100% perfect but need to see if i can repair/replace what's going on here. Looks to me like zero silicon in that corner wall join also which is probably not helping and may even be the main cause of what's going on.
Assume the process is something like.
- Remove grout with grout tool/saw
- Remove tiles (think i can get similar so not looking to replace whole wall but rather just what is required. I assume I smash and or pry them off?
- Clean up the wall behind the tiles… it's solid brick. So assume clean glue etc off the some sort of waterproofing?
- Then apply glue/tile cement, whack the tiles on, re-grout, silicon that corner join and the bath join and bob's you're aunty?
I know there's some good how to tile/grout guides on here, but any other step by step clues for a newbie would be so very much appreciated. Thanks all.
