We had a water leak recently and the plumbers needed to smash into quite a few tiles and through the concrete slab in our back veranda area. We have got new tiles ready for the tiler to lay, but first need to re-concrete the two holes made (see photos below). As you can see, one is pretty big, and the side will also need to be concreted flush. The other is fairly small.
I'm trying to work out if this is something fairly easy that I can do myself, or if I get someone to fix it. I've only ever concreted the base of a letterbox before, so I'm pretty inexperienced. The new tiles are quite expensive, and I don't want to risk making a mistake with the foundation if it's not an easy job.
Could someone give me any guidance on:
* How hard is this DIY job (and how easy is it to mess it up)
* If I do it myself, any tips for the process (i.e. do I need to remove loose rocks first, should I backfill some of the large area first, etc.)
* Roughly how much quantity of concrete does it look like I might need (based on image)
Cheers,
Stephen
