This project focuses on creating a custom lightsaber hilt using readily available materials from Bunnings. By combining PVC pipe, plumbing fittings, and other hardware, the project demonstrates basic fabrication, assembly, and finishing techniques. The finished hilt is lightweight, durable, and can be customized with paint and decorative details to reflect a unique design. The project highlights creativity, cost-effective construction, and practical DIY skills using common tools and materials.
M10 240mm Bolt -
https://www.bunnings.com.au/zenith-m10-x-240mm-hot-dip-galvanised-cup-head-bolts-nuts-each_p2444137
M10 Washers 3mm -
https://www.bunnings.com.au/pinnacle-m10-stainless-steel-flat-washer-6-pack_p0130535
M10 Washers 5mm
25x20mm Brass Threaded Hex -
https://www.bunnings.com.au/brasshards-25-x-20mm-brass-threaded-hex-reducing-bush-lf_p0572545
20mm Hexagon Socket -
https://www.bunnings.com.au/brasshards-20mm-brass-threaded-hexagon-socket-lf_p0572649
Brass Flared Compression Union -
https://www.bunnings.com.au/brasshards-15fl-x-15fi-brass-female-flared-compression-union-lf_p0572483
20mm Brass Threaded Adaptor -
https://www.bunnings.com.au/brasshards-20mm-brass-male-female-threaded-adaptor-lf_p0572507
M10 Locknut -
https://www.bunnings.com.au/pinnacle-m10-zinc-plated-nylon-lock-nut-4-pack_p0125995
2 Wrenches
Grab your M10 bolt, feed a 5mm washer down the bolt, put the top part of your compression union on it. Next, feed 1 5mm washer and then 2 3mm washers for a repeat of 6 times and then another 5mm washer. Next, put your threaded adapter on and then 2 3mm washers. Then, put your brass threaded hex on followed by 1 3mm washer, then a 5mm washer. Next, put your Hexagon socket on followed by a 5mm washer, and 2 3mm washers. Then you put the second part of your compression union on. Then put your M10 nut or locknut on and hold the base of the hilt with one wrench and tighten with the other - make sure everything is aligned and tighten the bolt.
