Need help with fixing my foundation garden. I had a couple of yucca trees in this area which i got grinded. The pulp is still within the ground. I am not sure how i should fix this area. I want something budget and easy to maintain, but also something which does not look cheap.
My solutions:
- One solution is putting stones how it was there previously. Install an edging and then put pots with plants in it. There are two main reasons for this solution, one is I am not sure with all the tree grinding in the soil any plants will grow there. And second is the right most section of this area which in the image is still covered in rocks has some concrete/cement thing there, not sure if is just a spill or there is an actual use for it.
- Second I can put pavers and then put rocks on side, and then i can put pots on pavers. This will be exactly same as rocks just pavers for extra stability for pots.
- Third option is a planter. This wall got weep holes near the ground level so i was thinking if i can have a slight gap from the wall and then put a single large planter in this area. Not sure how to build a planter or how difficult will it be to make. I don't really want to do cement pours, which i typically see people doing in online videos to fix the planters.
I am looking for what is the best thing to do here? What are my options?
Some other thoughts, I was planning on dig around the cement block/slab in right most part of the area and see what is going on there. Unless experts here say don't do it or its not worth the effort.
