Hi. I need to render this narrow section of garage brick wall where an extending wall has been removed. Once rendered I'll need to be able to bolt a fence post to it. I've done a bit of basic rendering before but this bit of wall has some bigger gaps and holes. Any advice on getting the tender to stick in place? Should I do filling first then top coat? I guess it will need to be pretty thick so as not to slump? I will be moving the small column water tank but the larger one (neighbours) is staying put.
Cheers
