1980's house and the laundry was tired. It had no bench top and minimal storage
Putty - Fill holes and cracking in plaster
Paint - Dulux
- Ceiling white
- Wash & Wear for the walls
- High gloss water base for the skirting boards, window frames and doors.
- Clear coat for bench top
Kaboodle - Cupboards
New sink
New taps
PVC fittings to connect drain from sink to outlet
Acrylic backsplash - Ensure you use the correct silicone to attach it.
Silicone and gap fillers
New benchtop - Merbau
Power tools
- Drill
- Jigsaw
- Drop saw
- Table saw
- Sander
- Vacuum cleaner
Hand tools
- Level
- Hammer
- Screw drivers
- Scraper
- Handsaw
- File
- Pliers
- Shifters
- Tape measure
- Pencil / markers
- Corking gun
- Broom
- Stanley knife
Painting
- Paint brushes
- Rollers
- Roller tray
- Stirrer
- Paint can opener
- Rags
- Drop sheets
- Putty for plaster
- Putty for timber
- Masking tape
Accessories
- Drill bits
- Screwdriver bits
- Packers
- PVC Cleaner and glue
- Teflon pastes and tape
- Sand paper
Removed all items from the laundry
- Step 2:
Prepare and painted the ceiling, walls, skirting boards, window frames, door frames and doors.
- Step 3:
Used the Kaboodle planning tool to work out what cupboards would fit and then installed the bottom cupboards, benchtop and sink (See photo above)
- Step 4:
I cut and installed the splash back to determine the overhead cupboard height and the new taps
- Step 5:
Installed the overhead cupboards and kick boards for the bottom cupboards.
I also installed kick boards on the sides of the bottom cupboards to fill the gap that would be left if not installed.
I was careful to choose the matching widths for the top and bottom cupboards, so they looked right
- Step 6:
Installed the washing machine and cleaned up.
