I needed to create a curved garden path so that I could align with a set of steps on a retaining wall. I chose to use a timber edge with a gravel infill.
90mm treated pine decking boards
Survey pegs
Geotextile fabric
Screws and staples
Deck stain
FCR base
Decorative gravel
Star pickets
steam Iron
Foil and rags
Saw
Battery drill
Paint brush
Wheel barrow
Shovel
I used a steam iron to curve the wood as I don’t have a steam box. First wrap the wood with a wet rag and then wrap with several layers of tin foil. Iron each side for at least 30 minutes, regularly turning. Then carefully bend the timber to desired curve using star pickets. Let cool down and keep retained by star pickets for a few days to hold its shape.
- Step 2:
The timber was coated with two coats of deck stain. I built the path by keeping the timber edge in position with survey pegs. Fabric was fixed with staples for weed control. FRC was put down as a base and gravel to finish.
