i found a rusty broken garden seat on the side of the road , Another persons junk was my gift. Better than new.
5 x Pinnacle M5 x 65mm Zinc Plated Round Head Bolts And Nuts - 4 Pack I/N: 0168405Cabot's 1L Jarrah Water Based Deck And Exterior Timber Stain - 1L I/N: 15201741x White Knight Rust Guard 300g Cottage Green Satin Touch Up Spray Paint I/N: 157003690 x 19mm Merbau SpecRite Pre-Oiled Decking - Random Lengths I/N: 0200172
spanner ans flat head screw driver
Trojan 4 x 15 Row Carbon Steel Wire Brush I/N: 0800585Stanley 8m Tape Measure I/N: 5660379Stanley 12" 305mm Mitre Box With Saw I/N: 0472669Paint Partner 75mm Paint Brush I/N: 0794479
1. Spray all bolts with WD 40
2. dismantle bench and measure timber span
3, strip all loose rust and flaking paint using a wire brush. Scrub the metal clean with warm water and detergent to remove grease and dirt. Once completely dry, wipe it down with mineral turpentine and apply a rust-inhibiting metal primer and spray paint with 2 coats of metal paint.
4. soak bolts in mineral turpentine to clean, if you can reuse use them.
5. measure lengths of slats work out how many metres you need, go to Bunnings pick your timber. I got them to cut to size as they needed to be uniform. If not use a mitre box to cut evenly.
6. stain the timber making sure you cover the cut ends.
7. Place in the garden and enjoy.
