Demo was first, we removed the existing sink, wall and floor tiles and the nib wall. We then lifted the floor in the entrance to match the rest of the room. Tilling next, large 30x60 black tiles across all the floor. Cupboards were installed above the bench and in the corner. Plumbing was moved, power point was lowered to under the bench and the sprinkler system was moved to an external wall. A new bench and sink was fitted with a splash back and lighting to suit. Finally dog bowls below the sink and wood panelling on the other wall.
wall panels:
https://www.bunnings.com.au/easycraft-easyvj100-general-purpose-9mm-900-x-1200mm-mr-mdf-e0-primed-white_p0330843?
under cupboard lighting:
https://www.bunnings.com.au/arlec-ultra-thin-cabinet-light-starter-kit-3-pack_p1048870
Sink Taps:
https://www.bunnings.com.au/ezyfix-chrome-lead-free-wall-sink-set-modern-lever_p0824711
Tiles:
https://www.bunnings.com.au/duratile-30-x-60cm-london-black-porcelain-floor-tile-carton-6_p0271116?
Splashback :
https://www.bunnings.com.au/wall-art-2400-x-1200-x-3mm-carrara-ice-wet-area-wall-shower-panel_p6660416?
Cupboards and Sink from Ikea
Tile Remover:
https://www.bunnings.com.au/dta-150mm-heavy-duty-floor-scraper_p6655833?
Tile spacers:
https://www.bunnings.com.au/qep-lash-tile-levelling-wedge-100-pack_p0393508?
Jigsaw for sink cutout:
https://www.bunnings.com.au/ryobi-18v-one-jigsaw-rjs18-tool-only_p0488988?
Wood saw for cutting bench frame:
https://www.bunnings.com.au/craftright-500mm-hand-saw_p0490022?store=5150
Holesaw kit for splashback holes:
https://www.bunnings.com.au/ryobi-5-piece-carbon-holesaw-set_p0727650?
Level for various uses:
https://www.bunnings.com.au/empire-600mm-compact-box-beam-level_p0019768
Tape measure for various uses:
https://www.bunnings.com.au/trojan-5m-tape-measure_p0423746?
Demolition
Remove old sink, nib wall and tiles
- Step 2:
Floor leveling and new door frame
Level floor in entry with concrete
Move door from from inset location to flush with hallway wall
- Step 3:
Floor Tiling
- Step 4:
Tiling Grout
Grout
- Step 5:
Electrical and Plumbing
- Step 6:
Cupboard Install
Custom install as was mounted right on the roof line
- Step 7:
Sink + Taps, Benchtop Install
- Step 8:
Splashback Install
- Step 9:
Custom dog feeder hidden under sink Install, can only see the end of the smaller pipe from usual viewing angles
Uses a Raspberry PI for control
- Step 10:
Wall Panel Install
