Hi, the tap underneath my laundry sink has starting to leak from the clamp. I’ve attached a photo. Could anyone tell me if I could fix this myself? Thank you.
Hello @Mona_Lena
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about the leaking clamp on your hose.
Please note that plumbing work needs to be completed by a licensed professional for safety and compliance.
If you are positive that the leak is originating from the clamped section and not travelling down the body of the hose head, odds are the material of the hose near the clamp has deteriorated. Because this hose end is machine fitted the entire hose will need to be replaced.
Please note that any changes that involve moving or reconfiguring pipework would be considered regulated plumbing work and would need to be carried out by a licensed plumber.
In this instance, I suggest engaging the services of a plumber to replace your washing machine inlet hose.
