Our kitchen was partly demolished/incomplete when we moved in, the whole L shaped part was bare. We found cabinets secondhand that matched our existing cabinets (the cabinets under the windows) but were different wood finishes so with the help of some paint we painted them and gave them a glow up with new handles, Bunnings wooden bench tops and completed the tiling too to just give it that finished look!
dulux aquaenamel - 4L in taubmans colour Carmen.
Hardwood panel -
https://www.bunnings.com.au/2400-x-600-x-33mm-hardwood-laminated-panel_p0618957?store=8211&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gbraid=0AAAAADtbEB9LT23XSqhSMYwydPHY-fNbx&gclid=CjwKCAjw6rfSBhAqEiwA_yocprgJgDDqyqTfxcuJEOaEWOLyaAUjYPgq10Bd0squ4UOtzt9czcenGRoCcTkQAvD_BwE
grout
https://www.bunnings.com.au/davco-1-5kg-white-sanitized-colourgrout_p6820064?store=8204&gclsrc=aw.ds&gad_source=1&gad_campaignid=21112196286&gbraid=0AAAAADtbEB_ChHqKFEAt4lwW_MQICa2pK&gclid=CjwKCAjw6rfSBhAqEiwA_yocplqSnF4LxT3tN4MAbcHRcjg9yb0O_BKsWh47vrMJvxsuaU7OaaDBqBoCKGAQAvD_BwE
Bench stain and seal
https://www.bunnings.com.au/bondall-250ml-walnut-monocel-stain-and-varnish-250ml_p1580823
https://www.bunnings.com.au/cabot-s-1l-satin-clear-benchtop-timber-finish_p1520590
flooring
Laminate- no longer stocked at Bunnings
Handles- Amazon
Tiles- left over from bathroom renovation
drop saw
https://www.bunnings.com.au/ozito-2100w-254mm-10-corded-double-bevel-sliding-mitre-saw-scms-2125_p6290588?store=8211
Multitool
https://www.bunnings.com.au/ryobi-18v-one-multitool-kit_p0249429?store=8211&gclsrc=aw.ds&gad_source=1&gad_campaignid=21118986128&gbraid=0AAAAADtbEB8bJePvaA4jR-yjjOIlfBVZD&gclid=CjwKCAjw6rfSBhAqEiwA_yocpuATNl-_r18IOefMyX6iRQ74rXatjQGh0XhdODDm1c_GQVxV_HIoNxoCL3cQAvD_BwE
Drill
https://www.bunnings.com.au/ryobi-18v-one-drill-driver-starter-kit-r18dd22_p0715241?store=8204&gclsrc=aw.ds&gad_source=1&gad_campaignid=21118986128&gbraid=0AAAAADtbEB8bJePvaA4jR-yjjOIlfBVZD&gclid=CjwKCAjw6rfSBhAqEiwA_yocpsHw4hdEUpRI9WaAeUFtEHzeIIQ7YH1pYjxf5uymGrG-H2CIrDUwPBoCEz0QAvD_BwE
Wagner spray gun
https://www.bunnings.com.au/wagner-w350-wood-and-metal-paint-sprayer_p0216877?store=8204&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gbraid=0AAAAADtbEB-TRVQh2dyZQxzCR-1erxBY7&gclid=CjwKCAjw6rfSBhAqEiwA_yocpnwsLMbw_Pyu2LCur7v2D_dwCkkAlQKfIX51bFUJTzzhyTU_gjfiZhoCXkUQAvD_BwE
trowel
https://www.bunnings.com.au/trojan-280mm-x-115mm-notched-plastering-trowel_p0551196
Sponge float
https://www.bunnings.com.au/builders-edge-280-x-140-x-130mm-hydrosponge-float-plaster-tool_p0730741?store=8204&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gbraid=0AAAAADtbEB9LT23XSqhSMYwydPHY-fNbx&gclid=CjwKCAjw6rfSBhAqEiwA_yocpuyrevAQXSpMooCGAZYG8D5LdWqpURTZEgeqFTcpVI0tHPOJkbLbGBoCMwYQAvD_BwE
Layed the flooring and then worked out the layout of where we wanted the cabinets to go and attached them to the walls
- Step 2:
cleaned down the surfaces with soapy water and sanded the doors ready for paint
- Step 3:
used the Wagner spray gun to prime and spray the doors in dulux aqua enamel
- Step 4:
reassembled cabinets and added handles to the doors and drawers
- Step 5:
cut timber benches to size and used the off cuts to create shelves between the upper cabinets. Stained them and sealed with a kitchen grade protectant
- Step 6:
tiled the splash back and in between the shelves to give it a high end finish
- Step 7:
grouted the tiles in white to give it a seamless look
- Step 8:
painted the existing cabinets to match the new cabinets added
- Step 9:
added some styling pieces and looked back at all the hard work I’d done to create the farmhouse kitchen of my dreams
just need to add some base board trims to complete it!
