House was built in a hurry to be a rental, so lots of cut corners and poor quality. We replaced the window, switched out the water damaged architraves for tile, retiled poorly done tiled wall, painted and upgraded appliances.
Taubmans undercoat coat paint and low sheen interior paint
https://www.bunnings.com.au/taubmans-4l-white-low-sheen-easycoat-all-walls-interior-paint_p0401018
https://www.bunnings.com.au/taubmans-500ml-white-easycoat-prep-sealer-and-undercoat_p0401009
Kitchen/bathroom gap filler
https://www.bunnings.com.au/sika-300ml-white-sikaseal-kitchen-and-bathroom-silicone-sealant_p1210308
Gyprock base coat
https://www.bunnings.com.au/gyprock-csr-3kg-wet-area-base-coat_p0730948
Giprock top coat
https://www.bunnings.com.au/gyprock-csr-2-25kg-less-mess-topping-compound_p0173348
Gyprock plasterboard
Subway Wall tiles
Powerstik
Grout
DeWalt orbital sander, mulitool, impact drill and vacuum
https://www.bunnings.com.au/search/products?page=1&q=Dewalt&sort=BoostOrder
Notch trowel
https://www.bunnings.com.au/qep-6mm-square-notch-handyman-adhesive-trowel_p6650391
Paint brush and roller
Plaster trowel
- Window replaced (the only part done by a contractor) and architraves removed.
- Step 2:
Tiles removed and plasterboard/concrete sheeting replaced
- Step 3:
Area around sink waterproofed and wall above tiles plastered.
- Step 4:
Wall tiles adhered, then grouted. Gap filler applied
- Step 5:
Plaster above tiles primed and painted
