Buying our first home was a dream come true, but it needed a little love. We headed to Bunnings, picked the perfect paint colour for the walls and fresh ceiling paint, then got to work. With every brushstroke, the house started to feel more like our home. The transformation was incredible—brighter, fresher, and full of life. It's amazing how a few tins of paint can completely change a space and create the perfect blank canvas for the memories we'll make together.
https://www.bunnings.com.au/taubmans-10l-white-low-sheen-endure-interior-walls-paint_p0024207
https://www.bunnings.com.au/taubmans-4l-ceiling-brilliant-white_p0401051
https://www.bunnings.com.au/taubmans-4l-white-semi-gloss-water-based-enamel-paint_p0147171
https://www.bunnings.com.au/scotchblue-24mm-x-54-8m-original-multi-surface-painter-s-masking-tape_p1669657
https://www.bunnings.com.au/uni-pro-500g-smooth-coat-skim-filler-500g_p1560087
https://www.bunnings.com.au/selleys-320g-liquid-nails-construction-adhesive_p1233751
https://www.bunnings.com.au/uni-pro-100mm-little-ripper-microfibre-mini-roller-covers-10-pack-4mm-nap_p1662564
https://www.bunnings.com.au/monarch-270mm-comfort-grip-roller-frame_p1560517
https://www.bunnings.com.au/monarch-270mm-doors-and-cupboards-ultra-microfibre-roller-cover_p1660026
https://www.bunnings.com.au/monarch-100mm-4mm-nap-3-piece-doors-trims-and-cupboards-mini-rollers_p0631963
https://www.bunnings.com.au/monarch-230mm-paint-tray_p1662148
https://www.bunnings.com.au/pro-renovator-50mm-wall-paint-brush_p1661752
https://www.bunnings.com.au/pro-renovator-50mm-trim-paint-brush_p1661758
https://www.bunnings.com.au/monarch-100mm-painters-bucket-100mm_p0328838
https://www.bunnings.com.au/uni-pro-heavy-duty-safety-paint-scraper_p1670219
https://www.bunnings.com.au/paint-partner-270mm-paint-roller-cover-3-pack_p0328962
https://www.bunnings.com.au/monarch-100mm-paint-tray-100mm_p1662146
https://www.bunnings.com.au/rocket-800g-wet-dry-sanding-block_p0472185
https://www.bunnings.com.au/9-3l-assorted-multipurpose-plastic-buckets-with-spout_p4461010
https://www.bunnings.com.au/wagner-1-22m-x-4-57m-4-x15-heavy-duty-dual-layer-drop-sheet_p0743506
https://www.bunnings.com.au/adoored-white-rubber-door-wedge-3-pack_p4061760
https://www.bunnings.com.au/gorilla-120kg-3-step-household-ladder_p0861100
https://www.bunnings.com.au/adoored-satin-chrome-trumpet-magnetic-door-stop_p4133223
https://www.bunnings.com.au/uni-pro-230mm-you-can-do-it-wall-and-ceiling-roller-cover-3-pack-10mm-nap_p1660020
https://www.bunnings.com.au/adoored-100mm-white-cushion-door-stop_p3961376
https://www.bunnings.com.au/monarch-expertech-heavy-duty-roller-frame-230mm_p0328985
Planned the project by creating a list of all the painting supplies and materials needed.
- Step 2:
Visited Bunnings Warehouse to purchase all required tools, paint, and preparation materials.
- Step 3:
Prepared the walls by patching over 100 holes, dents, and imperfections using multi-purpose filler.
- Step 4:
Sanded the repaired areas once the filler had dried to create a smooth, even surface.
- Step 5:
Applied masking tape to protect edges, trims, and other areas from paint.
- Step 6:
Cut in around the skirting boards and architraves using a brush and White Gloss Water Based Enamel Paint to create clean paint lines.
- Step 7:
Painted the skirting boards with White Gloss Water Based Enamel Paint and allowed them to dry.
- Step 8:
Rolled the ceiling (roof) with ceiling paint using a roller for an even finish.
- Step 9:
Rolled the walls with our choice of coloured paint, working section by section for consistent coverage. We used the colour 'Cotton Sheets' by Tubman's.
- Step 10:
Removed the masking tape and completed a final inspection, touching up any areas that required additional paint. Voila!
