We turned one of our bedrooms which we were using as a office into a nursery for our little boy arriving in October, with the main piece being the bay leaf feature wall that was highlighted with MDF boards to create the paneling. The wall completely changed what was a plain and boring room into our new favourite room of the house.
- Sellys liquid nails
- Sellys white caulk
- 92mm x 2700mm primed mdf board
- Porter paints, bay leaf colour
- Frames with prints inside
- Hooks for frames
- Caulking gun
- Ozito cordless circular saw
- Tape measure
- Painters tape
- Paint brush and paint roller
- Ozito electric sander
- Hammer
- Microfibre cloths
measured hight and length of wall to calculate length of boards
- Step 2:
cut mdf boards to size.
I wanted to panel the top, each end of the wall and two panels in the middle of the wall.
- Step 3:
the bottom existing scirting board that ran along the floor had a beveled edge so the bottom of the boards going up and down had to be cut with an edge to match neatly on top.
- Step 4:
once boards are cut and you’ve checked they fit snuggly where you want them it’s time to stick them with liquid nails using the caulking gun.
You’ll need to hold the boards firmly until the liquid nails takes hold.
- Step 5:
once the liquid nails has set sand any areas that require it
- Step 6:
use your caulking gun again to fill the gaps with white gap filler around your new panels so that the look neat and apart of the wall. I used damp micro fibre cloths to help wipe any messy caulking.
- Step 7:
when the caulking is dry sand again
- Step 8:
now paint with the desired colour, in our case it was porter paints bayleaf. We put painters tape around all the boarders where we didn’t want the bayleaf to go onto
We applied two coats using a brush for the edges and roller for the rest.
- Step 9:
hang the frames between the panelling. We used a hammer to put the hooks in for the frames to hang on.
