Custom built-in entertainment unit designed to maximise storage and transform an unused wall into a functional feature. The project includes Kaboodle cabinetry, solid timber benchtops and shelving using Tasmanian Oak, an Easycraft VJ panelled TV feature wall, and a wall mounted TV
https://www.bunnings.com.au/2200-x-600-x-28mm-tasmanian-oak-fj-feature-grade-panel_p0520567
https://www.bunnings.com.au/1800-x-600-x-19mm-timber-panel-tasmanian-oak-fj-laminated-feature-grade_p0215400
https://www.bunnings.com.au/1800-x-405-x-19mm-tasmanian-oak-fj-feature-grade-panel_p0520566
https://www.bunnings.com.au/timbermate-250g-hardwood-wood-filler_p1563594
https://www.bunnings.com.au/irwin-125mm-240-grit-8-holes-quick-fit-random-orbital-sanding-discs-5-pack_p0477639
https://www.bunnings.com.au/ryobi-8mm-fluted-dowel-100-pack_p0466321
https://www.bunnings.com.au/zenith-8g-x-50mm-gold-passivated-countersunk-rib-head-chipboard-screws-500-pack_p2420689
https://www.bunnings.com.au/selleys-100ml-aquadhere-pva-wood-glue-interior-adhesive-100ml_p1230622
https://www.bunnings.com.au/bondall-1l-monocel-waterbased-clear-varnish-gloss_p0079564
https://www.bunnings.com.au/monarch-75mm-woodcare-paint-brush_p0022591
https://www.bunnings.com.au/kaboodle-900mm-medium-wall-cabinet_p0957348
https://www.bunnings.com.au/kaboodle-push-to-open-door-hinge-1-pair_p2662007
https://www.bunnings.com.au/kaboodle-adjustable-cabinet-legs-4-pack_p0515715
https://www.bunnings.com.au/kaboodle-450mm-antique-white-heritage-med-cabinet-door_p0996306
https://www.bunnings.com.au/kaboodle-antique-white-base-filler-panel_p2666474
https://www.bunnings.com.au/138-x-18mm-5-4m-white-moulding-pine-fj-primed-dar_p0020753
https://www.bunnings.com.au/easycraft-easyvj100-general-purpose-9mm-2400-x-1200mm-mr-mdf-e0-primed-white_p0330364
https://www.bunnings.com.au/selleys-320g-liquid-nails-construction-adhesive_p1233751
https://www.bunnings.com.au/hume-42-x-18mm-5-4m-moulding-white-mdf-primed-bevel_p8470064
https://www.bunnings.com.au/porta-quad-12-x-12mm-tasmanian-oak-3m_p0080630
https://www.bunnings.com.au/taskmaster-15mm-white-self-adhesive-screw-caps-250-pack-white-250-pack_p0537814
https://www.bunnings.com.au/selleys-475g-no-more-gaps-interior-multipurpose-gap-filler-3-pack_p1232399
https://www.bunnings.com.au/dulux-4l-1step-prep-primer-sealer-undercoat_p1370234
https://www.bunnings.com.au/dulux-4l-lexicon-quarter-low-sheen-ready-to-go-colour-wash-wear-interior-paint_p0638877
https://www.bunnings.com.au/monarch-230mm-walls-ceilings-ultra-microfibre-roller-cover-3-pack_p1662706
https://www.bunnings.com.au/sanus-42-90-tilting-tv-wall-mount-bracket_p0247048
https://www.bunnings.com.au/powerfit-c-series-electro-galvanised-brad-nails-project-pack_p0728540
https://www.bunnings.com.au/paint-partner-230mm-disposable-clear-tray_p0328969
https://www.bunnings.com.au/scotchblue-24mm-x-54-8m-original-multi-surface-painter-s-masking-tape_p1669657
https://www.bunnings.com.au/poly-390g-gloss-fine-finish-filler_p1210357
https://www.bunnings.com.au/makita-18v-random-orbital-sander-dbo180z-skin-only_p6290239
https://www.bunnings.com.au/makita-18v-brushless-2-piece-combo-kit-dlx2283sm_p0090871
https://www.bunnings.com.au/makita-18v-165mm-brushless-circular-saw-dhs680z-skin-only_p6240314
https://www.bunnings.com.au/ryobi-400w-trim-router-rtr400-s_p6210607
https://www.bunnings.com.au/dewalt-305mm-corded-compound-mitre-saw-w-stand-dws780-xe_p0441385
https://www.bunnings.com.au/makita-18v-18ga-c1-brad-nailer-dfn350z-skin-only_p0501086
https://www.bunnings.com.au/stabila-3-pack-level-spirit-and-bag_p0271672
https://www.bunnings.com.au/irwin-300mm-quick-grip-mini-clamp-2-pack_p0215574
https://www.bunnings.com.au/ryobi-4-piece-countersink-drill-bit-set_p0525187
https://www.bunnings.com.au/uni-pro-skeleton-caulking-gun_p1670517
https://www.bunnings.com.au/monarch-expertech-heavy-duty-roller-frame-230mm_p0328985
- Square
- Tape measure
- Hammer
- Pencil
- Safety glasses
- Ear protectors
Design
I used AI to give me a starting point and then designed and drew up the final idea
- Step 2:
Cut & Sand Timber
- I cut all the wooden panels to size with a circular saw, using a level and clamps to act as a straight guide. Next, I used the router to add some rounded edges to the front of the shelve and benchtop part. I then filled any imperfections with Timbermate wood filler and once that dried, I used the orbital sand with 240grit pads to sand everything
- Step 3:
Assemble Timber Cabinets
I used a drill and wooden dowels with some wood glue to put the wooden panels together. I added wood screws on any edge that wouldn’t be visible to increase the strength.
- Step 4:
Stain Timber
I stained all the timber with three coats of Moncel clear varnish, allowing 24 hours to dry and sanding lightly between coats.
- Step 5:
Assemble Kaboodle Cabinets
I assembled all the kaboodle cabinets with the drill and driver. I used kaboodle cabinets legs to set the height, they allowed me to make sure the wooden cabinets fit snug on top without hitting the roof. Once they were all level I used 65mm screws to secure them to the walls
I used kaboodle filler panels to cover the gaps on the sides. For the baseboard I used a piece of pine moulding and the clips that come with the kaboodle legs.
- Step 6:
Instal Timber Cabinets and Benchtop
I lifted the two wooden cabinets into place, levelled them and then fixed them to the studs in the walls and roof with 65mm brads, leaving a small gap to allow for expansion of the wood. I then covered all the visible fixing holes in the timber with more timbermate wood filler. I then cut the middle part of the benchtop to fit in between and installed that by screwing up from inside the base cabinets below to hide all fixings.
- Step 7:
Instal VJ Lining Boards and Trim
I cut the easy VJ lining boards to size and used liquid nails and the brad nailer to fix them to the wall. I used the 42 x 18 moulding to give a nicer finish between the lining boards and the benchtop / roof. I then used the 12mm Tasmanian oak quad to cover the gaps left around the timber cabinets. I used Polyfilla on the VJ and moulding and more timbermate on the quad to hide all the nails
- Step 8:
Fit Push to Open Doors
At this stage I finished fitting all the kaboodle doors off correctly and installed all the push to open hardware. I also used white cabinet stickers to cover all the screws inside the cabinets
- Step 9:
Gap Filler & Paint
I used gap filler around the easy VJ lining boards, the baseboard and between the filler panels and walls. Once that was dry I painted the lining boards and baseboard using Dulux Primer as a base coat and 2 coats of Dulux Lexicon Quarter in the low sheen
- Step 10:
Hang TV
Last thing to do was reinstall the tv bracket and put the tv back up
Final Photos
The project took around 5 days total. 1 day designing, 2 days spent making the timber cabinets and 2 days installing
