I had a narrow space outside the alfresco that did not get enough sunlight, and it was lying barren for some time, till I came across “shade-loving plants” on the Bunnings website. I did a little bit of research and came across the amazing-looking Helleborus which were available at Bunnings. I found the perfect terrazzo-look pots and bowls, polished white pebbles and a mix of shade loving plants for a perfect blend of colour in the bowls. Once the project was completed, it was super satisfying and added a touch of glamour and life to the space!
Removed old stones, dead plants and weeds and cleaned up the space.
- Step 2:
Added a bag of soil to level the ground. Used a rake to spread the soil and compact the ground.
- Step 3:
Spread the weed mat and set up the two raised stands (wire mesh), added stones in the wire mesh to create the strong base for the two bowls.
- Step 4:
Planted the mix of plants in the two bowls and the Hellebores in the large and medium pots
- Step 5:
Placed the bowls on the raised stands and the pots in place with pot feets and brick blocks to allow drainage. Placed three brick blocks to create and edge on one side.
- Step 6:
Then finally added the white pebbles to finish the project. Added a few solar lights for a dash of light in the evening!
