Front of house reception desk - This desk all came to life when my wife and I couldn't find something to suit the space we had created, Started with a rough sketch with no radius than turning into what it is today.
A beautifully modern and well presenting timeless piece.
x 70 x 35mm treated pine framing timber
2 sheets of 12mm structural plywood (top and base)
1 sheets of 4.5mm fibre cement sheeting (for the curved cladding)
1 box of 65mm timber screws
1 box of 30mm fibre cement screws
Construction adhesive
Flexible gap filler / polyurethane sealant
PVC external corner beads
Fibreglass joint tape
Cement-based joint compound
2-3 bags of render (Rockcote Coarse Render / patch and prep)
Masonry primer
Exterior paint (colour of choice)
Circular saw or mitre saw
Jigsaw
Drill/driver
Impact driver
Clamps
Tape measure
Spirit level
Utility knife
Trowel and hawk
Mixing bucket and paddle mixer
Orbital sander
Build the Frame
Construct the frame using treated pine, making sure it's square and sturdy. Cut the curved top and bottom pieces from plywood to create the rounded front.
- Step 2:
Install the Cladding
Fix flexible fibre cement sheets to the frame using fibre cement screws. Take your time bending the sheets around the curve for a smooth finish. Tip - If using cement based sheeting, dampen prior to bending for best result
- Step 3:
Prepare for Rendering
Install PVC corner beads on all external corners and reinforce all joints with fibreglass tape. Apply patch and prep to all Joints prior to Base coating.
- Step 4:
Apply the Render
Apply a coat of Patch and prep to the entire surface Bedding in fibreglass reinforcing mesh, before finishing with a fine skim coat of course Rockcote render and float or sponge to perfection
- Step 5:
Prime and Paint
Apply a quality masonry primer followed by two coats of exterior paint. The finished desk has a durable, seamless look that's perfect for a modern reception area.
