A solid wood Hevea table top with black metal ‘U’ legs. To strengthen the table top and give it a more solid look I added an under base from MDF.
I purchased two Hevea panels
1200 x 405 x 18mm
MDF base board
Black ‘U’ metal legs: heavy metal brackets
screws, hard wax, clear coat
All my battery tools are OZITO
I use 3 drills: to drill, screw counter sink.
Makes it easier not having to change BITS
Wood glue, sand paper,
I drilled 4 dowel holes along each panel, glued and clamped together to make an 800width table top. Glued the MDF to the underside to strengthen the table. Attached the metal legs and added heavy gage metal brackets for extra support. Sanded with 180 and used a clear coat and hard wax finish.
