Tile is broken in my patio, I need suggestion to fix the tile
Hello @anilkumar3009
Thank you for sharing your question about how to fix your broken tiles. If you have similar spare tiles at home, I suggest removing the broken ones and replacing them with your spare tiles. This will involve removing the grout using a https://www.bunnings.com.au/qep-professional-grout-saw_p0393523 . Once the broken tiles are isolated you can use a small https://www.bunnings.com.au/trojan-8oz-225g-fibreglass-ball-pein-hammer_p0492154 to break the broken tiles to remove them. My best advice is to tap the broken piece moderately so that it does not shatter the surrounding tiles around it.
Once the broken tiles are removed the concrete base is cleaned and all the old adhesive is removed using a https://www.bunnings.com.au/trojan-6-in-1-multi-paint-scraper_p0093215 . You then apply new tile adhesive, and the new tiles are glues into place.
However, if you don't have replacement tiles and can only re-glue the broken pieces, I suggest checking the number pf pieces that you have to make sure that the damaged area can still be fully covered. I suggest using https://www.bunnings.com.au/dunlop-310ml-tile-all-plus-premixed-tile-adhesive_p6650104 to re-attach the broken tile back to the concrete surface. Before you begin, I suggest cleaning the concrete base with https://www.bunnings.com.au/30-seconds-2l-outdoor-cleaner-concentrate_p4463155 along with a bristle brush.
Please remember to wear personal protection such as gloves, goggles and a mask.
