the mini Bunnings buckets were the perfect size to hold a single strawberry plant and with the handle was super easy to hang, being hung the way it is also means no crawling insects or bugs can eat the plants.
8/10 mini Bunnings buckets
3 mtr chain or rope whatever suits
2 wooden poles the same length,( you can do it any length you want )
4 screws to attach chain to the end of the pole
S hooks to hang the buckets on the pole.
Make as many as you want.
drill with small drill bit
Screwdriver to put in the screws
Saw to cut the poles to length
1, this is the part where you can recycle, I used an ol wooden curtain rod and cut it into 2 equal pieces
2 I used a small drill bit to drill a central hole
3 I then attached the chain at equal points to the end of the pole with he screws using the loops of the chain, with enough at the top to hang.
4 with the drill drill holes in the bottom of the buckets for drainage, use your own discretion as to how many holes you need
5 plant the strawberries one to a pot and hang on pole with S hooks.
6 water and enjoy.
